Unsolved Emergecy Stop and sd card
Hi.
When i use the emergency stop button and then reset button in DWC the sd card gets erased. I have to format, install og configure it all again. Is this normal behaviour? -
@hsverre It most certainly is not. I cannot really provide any idea as why it would be happening for you though. You could maybe try with a different sd-card to eliminate a fault sd-card.
@nxt-1 Thanks for the reply, this is the second sd card i use, just to make sure the problem is not with the card.
@hsverre Are you using the latest stable firmware version v3.3?
@chrishamm Im using version 3.2.2
@hsverre Does this happen when you run M999? If not, it may be an electrical problem, not firmware.
Can you provide us the results of M122 please?
@phaedrux m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
Board ID: 0JD0M-9P6M2-NW4SN-6J1FD-3S46K-KUSRM
Used output buffers: 3 of 24 (11 max)
Static ram: 23876
Dynamic ram: 75528 of which 24 recycled
Never used RAM 14988, free system stack 184 words
Tasks: NETWORK(ready,14.1%,229) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) DUEX(notifyWait,0.0%,24) MAIN(running,85.6%,441) IDLE(ready,0.2%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:06:07 ago, cause: power up
Last software reset at 2021-07-29 22:51, reason: User, GCodes spinning, available RAM 14988, slot 1
Error status: 0x00
Step timer max interval 0
MCU temperature: min 23.3, current 31.7, max 32.1
Supply voltage: min 12.3, current 12.5, max 12.6, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 5: position 0, standstill, SG min/max not available
Driver 6: position 0, standstill, SG min/max not available
Driver 7: position 0, standstill, SG min/max not available
Driver 8: position 0, standstill, SG min/max not available
Driver 9: position 0, standstill, SG min/max not available
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-07-30 09:33:00
Slowest loop: 4.06ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.6ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== DueX ===
Read count 1, 0.16 reads/min
=== Network ===
Slowest loop: 15.60ms; fastest: 0.00ms
HTTP sessions: 2 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address 24:a1:60:2f:8b:f0
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 22280
WiFi IP address 192.168.10.204
WiFi signal strength -68dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
Are you able to reliably trigger the wipe of the SD card or is it more random?
