    New X Y motors stall problems
    • SaveThePetko
      SaveThePetko last edited by
      Hi , i changed my X Y motors to E3D with 0.9degree and now my homing absolutly not working . its crash and crashing than stop with error Homing Failed .
      config.g :
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Jul 15 2021 19:20:56 GMT+0200 (Central European Summer Time)
      M550 P"Prusa i3" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards X
      M569 P1 S1 ; physical drive 1 goes forwards Y
      M569 P2 S0 ; physical drive 2 goes forwards Z
      M569 P3 S1 ; physical drive 3 goes forwards E
      M92 X200 Y200 Z397.48 E394.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z650 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-2.4 Y-6 Z0 S1 ; set axis minima
      M208 X250 Y210 Z240 S0 ; set axis maxima
      M574 X1 S3 ; configure sensorless endstop for low end on X
      M574 Y1 S3 ; configure sensorless endstop for low end on Y
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P1 C"zprobe.in" H5 F300 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      M308 S2 P"e1_temp" A"Pinda V2" Y"thermistor" T10000 B3950 ; pinda v2
      G31 P500 X45 Y20 Z-0.15 ; set Z probe trigger value, offset and trigger height
      M557 X30:230 Y0:186 S50 H5 ; define mesh grid
      M950 F0 C"fan0" Q100 ; create fan 0 on pin fan0 and set its frequency
      M950 F1 C"fan1" Q100 ; create fan 1 on pin fan1 and set its frequency
      M915 X Y S15 R0 ; zmena sensityvity na motoroch X a Y
      T0 ; Nastavenie na Hrot 0
      G29 S1 ; Nacitanie kompenzacie heatbedu
      homeall.g :
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Jun 27 2021 18:14:24 GMT+0200 (Central European Summer Time)
      M400 ; wait for current moves to finish
      M915 X Y S30 R0 ; zmena sensityvity na motoroch X a Y
      M913 X40 Y40 ; drop motor current to 70%
      G91 ; relative positioning
      G1 H2 Z5 F8000 ; lift Z relative to current position
      G1 H1 X-260 Y-220 F8000 ; move quickly to X axis endstop and stop there
      G90 ; absolute positioning
      G1 X110 Y85 F9000 ; move to middle of bed plus probe offsets
      G30 ; home z0
      homex.g
      ; homex.g
      ; called to home the X axis
      ;M400 ; dokoncenie vsetkych pohybov
      ;M915 X S10 R0 ; zmena sensityvity na motoroch X a Y
      ;M913 X70 ; drop motor current
      ;G91 ; relative positioning
      ;G1 H2 Z5 F12000 ; lift Z relative to current position
      ;G1 H1 X-260 F5000 ; move quickly to X axis endstop and stop there
      ;G90 ; absolute positioning
      ;M913 X100 ; return current to 100%
      M400
      M915 X Y S50 R0 ; zmena sensityvity na motoroch X a Y
      M913 X70 Y70 ; drop motor current to 70%
      M400 G91; relative positioning
      G1 H2 Z10 F12000 ; lift Z relative to current position
      G1 H1 X-250 F6000 ; move quickly to X axis endstop and stop there (first pass)
      M400
      M913 X100 Y100 ; return current to 100%
      M400
      homey.g :
      ; homey.g
      ; called to home the Y axis
      M915 Y S10 R0 ; zmena sensityvity na motoroch X a Y
      M913 Y70 ; drop motor current to 70%
      M400 G91 ; relative positioning
      G1 H1 Y-220 F8000 ; move quickly to X axis endstop and stop there (first pass)
      M913 Y100 ; return current to 100%
        You're using sensorless homing and just changed the motors, so you will need to retune the stall detection parameters.
        https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
        SaveThePetko 1 Reply Last reply Reply Quote 0
        • SaveThePetko
          SaveThePetko @Phaedrux last edited by SaveThePetko
          @phaedrux
          and how i tune it i changed :
          ; homey.g
          M915 Y S3 R0 F0 ; zmena sensityvity na motoroch X a Y
          M915 Y Sn , i change n to everithing in low numbers it wont move and if i change it to higher number its crashing .
          m569 p0
          Drive 0 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos unknown
            You need to read that link carefully. Have you calculated what your M915 H value should be? You've doubled the number of steps per mm.
            • SaveThePetko
              @phaedrux how i calculate it ? m915 H
              Im added H400 to M915 changed S to 0 and now its homing X and Y fine .
              engikeneer 1 Reply Last reply Reply Quote 0
              • engikeneer
                engikeneer @SaveThePetko last edited by
                @savethepetko from the page @Phaedrux linked: d912fd94-b515-4e29-98e0-1fbced35f577-image.png
                If it's working reliably for you, then all good, but might still be worth going through that guide properly as stall detection can change a bit as the motors heat up.
                i3 clone with a bunch of mods
