    Printing at Sloth Speeds
    • TimsWorkshopundefined
      TimsWorkshop
      I mean, don't get me wrong, I loved the movie 'Zootopia' and the sloth... but not super keen when it comes to my printer speed.
      Background... I just finished setting up my Duet2 Wifi on my Ender 5 Plus and have all the wiring done. All axis homes correctly, extruder works, nozzle, bed, everything works. When I home, it moves at my designated speed, nice and fast, but not too fast. Z homes great with the new EZABL Pro, happy days.
      SO... I went to print a bed level test of 5 squares, and wow.... When everything heats up, it does a homing sequence and it moves slooooooooowwwwwww.
      I let it home, after about 90 seconds.... then it started to print, and again, slooowww! Filament would extrude, it's printing the pieces as they should.. but just at sloth mode.
      So I did some searching and saw to check my M556, M203, and M201 E speeds, which I did.
      M566 X900.00 Y900.00 Z300.00 E2000.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z900.00 E6000.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z500.00 E3000.00
      Did a reset and still in Sloth mode.
      I also checked the M201 setting in the gcode and it looked fine as it prints fine on Marlin
      M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
      I found a reddit post where the guy said he got it fixed... but the dude didn't post the solution... Just said it had something to do with Cura settings.
      This is the start of my cura gcode file
      M140 S60
      M105
      M190 S60
      M104 S200
      M105
      M109 S200
      M82 ;absolute extrusion mode
      M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
      M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
      M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
      M220 S100 ;Reset Feedrate
      M221 S100 ;Reset Flowrate
      G28 ;Home
      M420 S1 Z2 ;Enable ABL using saved Mesh and Fade Height
      G92 E0 ;Reset Extruder
      G1 Z2.0 F3000 ;Move Z Axis up
      G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
      G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
      G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
      G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
      And because I want to be in-depth, here's my config.g file
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Jun 05 2021 07:45:39 GMT+1000 (Australian Eastern Standard Time)
      M550 P"Oneill"                                     ; set printer name
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E420.00                  ; set steps per mm
      M201 X500.00 Y500.00 Z500.00 E3000.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M208 X0 Y0 Z-2 S1                                   ; set axis minima
      M208 X350 Y350 Z400 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      ;M558 P1 C"zprobe.in" H5 F120 T6000                 ; set Z probe type to unmodulated and the dive height + speeds
      M558 P5 C"!zprobe.in" H3 F900 T12000
      G31 P500 X0 Y0 Z4.80                                ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      ; Filament Runout Sensor
      M591 D0 P1 C"e0stop" S1
      ; TFT Display Config
      M575 P1 S1 B57600
      M501                                               ; load saved parameters from non-volatile memory
      Any help to get out of sloth mode would be very much appreciated! 🙂
      Thanks!
      Ender 5 Plus - E3D Hemera Hotend - Duet 2 Wifi
      TimsWorkshopundefined 1 Reply Last reply Reply Quote 0
        TimsWorkshop @TimsWorkshop
        Did some more searching and found the problem
        Apparently these lines are the culprit... so I removed them and tried printing again...
        engikeneerundefined 1 Reply Last reply Reply Quote 0
        • engikeneerundefined
          engikeneer @TimsWorkshop
          @infidelprops yup, those looke like old Marling numbers.
          FYI, RRF & Marrlin use different units for feedrates & jerk - Marlin uses mm/s whereas RRF uses mm/min, so 500 mm/min would mean it would take ~25s to move across a 200mm bed! Compare the M203 numbers in your config to what you were overriding them with in your start gcode and you'll see the difference
          In general you should be able to set up sensible machine limits in your config and not need to change them in slicer, though you can play around with different speeds/accels for different feature types like infill or perimieters if you want.
          I would also double check that your slicer is set to RRF flavour and not Marlin 🙂
          i3 clone with a bunch of mods
            TimsWorkshop
            @engikeneer Thanks mate! After I found the issue, I did check my printer settings in Cura and removed the start code and set it to RR versus Marlin.
            Good shout out!
