    Solved Is there a script run for "Tool 0" ?
    Duet Web Control
    • jens55
      jens55 last edited by
      When I click on "Tool 0" on the DWC screen, what script if any is being run? I am wondering what all that button does.
      MikeS OwenD 2 Replies Last reply Reply Quote 0
      • MikeS
        MikeS @jens55 last edited by
        @jens55 it sets tool 0 as the active tool. If you have only one, you can add "T0"at the end of config.g to enable it automatically at startup.
        jens55 1 Reply Last reply Reply Quote 0
        • jens55
          jens55 @MikeS last edited by jens55
          @mikes, thanks but I am trying to find out exactly what the button does. What is the equivalent Gcode? Is it "T0" or "T-1" followed by "T0" or something else? Is the function hard coded or is there a gcode file that it runs where I could change it's action ?
          • OwenD
            OwenD @jens55 last edited by
            @jens55
            It will send T0
            That in turn may run other tool change macros.
            See here
            https://duet3d.dozuki.com/Wiki/Gcode#Section_T_Select_Tool
            jens55 2 Replies Last reply Reply Quote 1
            • jens55
              jens55 @OwenD last edited by
              @owend, thanks.
              • jens55
                @owend said in Is there a script run for "Tool 0" ?:
                See here
                After more studying and contemplation, this link proved to be the answer.
                Thank you !
