Unsolved workplace.Offset and virtual axes
Hi gents,
I'm trying to use move.axes[n].workplaceOffsets[1] as variable array. To allow 9 values to be stored I have to define virtual axes.
I triedM584 X0 Y1 Z2 E3:4 U5 V6 W7 A8 B9 C10 P3
and they all appeared in the object model. But when try to init them all with "-1"
G55 G10 L2 X-1 Y-1 Z-1 U-1 V-1 W-1 A-1 B-1 C-1 G54
only the real XYZ offsets show a value of -1
echo move.axes[4].workplaceOffsets[1] 0.000 echo move.axes[5].workplaceOffsets[1] 0.000 echo move.axes[0].workplaceOffsets[1] -1.000
What else does it need, to make the virtual axes accept workplace offsets?
@o_lampe the axes need to be visible to set workplace offsets for them using G10, and to retrieve them from the object model.
...and G10 L2 is the only way to fill the array or alter single values later?
