    Solved Invalid heightmap? Thoughts?
    Using Duet Controllers
    1
    • CNCModeller
      CNCModeller last edited by
      Hi All,
      Been having some adhesion problems with a large dia dense print (720T GT2 Pulley) so decided to try mesh compensation.
      Not sure what's wrong with this heightmap? DWC says its invalid?
      Its a circular bed dia 600mm with the origin at the centre, on a polar printer.
      Both axes moved albeit its a little tricky to follow given the polar co-ordinate motion.
      Thoughts?
      Cheers
      BPM
      RRF 3.4 beta 3 on a duet 3 Mini+
      Commands used:
      M557 R250 S100
      G29
      Console:
      G29
      21 points probed, min error -0.152, max error 0.131, mean -0.065, deviation 0.062
      Height map saved to file 0:/sys/heightmap.csv
      Heightmap:
      RepRapFirmware height map file v2 generated at 2021-09-27 19:00, min error -0.152, max error 0.131, mean -0.065, deviation 0.062
      axis0,axis1,min0,max0,min1,max1,radius,spacing0,spacing1,num0,num1
      X,Y,-200.00,200.10,-200.00,200.10,250.00,100.00,100.00,5,5
      0, -0.066, -0.084, -0.055, 0
      -0.100, -0.025, -0.010, -0.117, -0.090
      -0.087, 0.045, 0.131, -0.112, -0.152
      -0.095, -0.043, -0.009, -0.120, -0.107
      0, -0.093, -0.095, -0.087, 0
      Polar Printer Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      Wanhao D5S & K40 Laser, Duet2 TBD
      https://www.youtube.com/CNCModellerUK
      • CNCModeller
        Solved, old version of DWC (3.2 not 3.4) , DOH!
        Wanhao D4S: Duet2
