    M669: S & T variables... my brain hurts!!!
    180
    • CNCModeller
      CNCModeller last edited by
      Hi All,
      I've been tuning up my printer to increase print speed, having been unable to get the printer to reach desired speed with higher S and lower T I set them to the following:
      M669 S50 T0.5
      I'm using polar kinematics, the printer now prints at the demanded speed, but I have no idea why, in my mind 50 seg/s at 0.5mm/seg = 25mm/s but I'm getting much more than that. I obviously don't understand what these settings mean. Can anyone please enlighten me, it doesn't seem to be explained clearly in the documentation anywhere.
      M669: Set kinematics type and kinematics parameters
      Snnn Segments per second (because smooth XY motion is approximated by means of segmentation)
      Tnnn Minimum segment length (mm) (because smooth XY motion is approximated by means of segmentation)
      Any constructive thoughts would be much appreciated!!!
      Cheers
      Barry M
      Polar Printer Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      Wanhao D5S & K40 Laser, Duet2 TBD
      https://www.youtube.com/CNCModellerUK
      oliof JoergS5 2 Replies Last reply Reply Quote 0
      • oliof
        oliof @CNCModeller last edited by
        @cncmodeller
        S is an absolute number of segments. So 50 segments per segment.
        T is the minimum segment length. So even if you were to set the number of segments per second to 1000, and printed at 50mm/sec, you'd still only get 100 segments with T0.5, because segments won't be shorter than 0.5mm.
        Let's say you print at 50mm/sec and 50 segments/per second. Then each segment is 1mm and longer than minimum segment length.
        (this is assuming that T is prioritized over S).
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
        CNCModeller 1 Reply Last reply Reply Quote 0
        • CNCModeller
          CNCModeller @oliof last edited by CNCModeller
          @oliof, that makes sense to me, so what is a segment? Is it a chunk / packet of demand outputs to the drivers?
          Its now obvious to me that its not the minimum straight line length, i.e. like the triangle sizes in an STL file.
          I also don't understand why if I set S to 1 it doesn't seem to make any difference...???
          Brain still hurts lol
          Wanhao D4S: Duet2
          oliof 1 Reply Last reply Reply Quote 0
          • oliof
            @cncmodeller The slicer makes GCode move commands from the STL. The GCode only coincidentally sometimes* recreates something where you can see the original STL on low resolution files.
            What GCode does not know is how the move command is actually executed by the 3d printer, because GCode is (usually) kinematics agnostic**
            Depending on the kinematics (how the printer actually positions the print head), it may be required that a GCode move command is split up into smaller moves. Those are called segments.
            *most of the time. Except if you use something like ArcWelder to re-approximate curved surfaces.
            ** experimental kinematics sometimes required GCode post processing.
            • JoergS5
              JoergS5 @CNCModeller last edited by JoergS5
              @cncmodeller said in M669: S & T variables... my brain hurts!!!:
              polar kinematics
              If you print a long straight line on a polar printer without segmentation, you'll get a curved line, because the stepper's speeds stay at a planned value and stepper to coordinates is non-linear.
              To solve this, the line is segmented into smaller lines, where the stepper's speeds are calculated for every segment. The result is, the smaller segments are nearly straight lines. Still not straight, but if you make enough segments, straight enough.
              Calculation of the segments needs additional computing power, so it depends on the Duet version which values can be set.
              CNCModeller 1 Reply Last reply Reply Quote 1
              • CNCModeller
                CNCModeller @JoergS5 last edited by
                Thanks @JoergS5 that's really interesting.
                So is it fair to say that course segmentation wouldn't affect small geometry?
                Is the minimum segment length that which if a move is shorter segmentation is not applied?
                Just trying to get a first principles feel for how it works. 🙂
                @joergs5 said in M669: S & T variables... my brain hurts!!!:
                polar kinematics
                Wanhao D4S: Duet2
                JoergS5 1 Reply Last reply Reply Quote 0
                • JoergS5
                  If you mean, small geometry is not affected by segmentation because they are small and you will not see a difference, so yes, if the object size is maybe in the 0.5 mm range. It depends how good your printer is, you'll your printer will have other imperfections which are weighing more. For nano printers it's different, of course.
                  Segmentation is a means to divide curved lines into short straight lines, so the Cartesian or CoreXY kinematics can print them, printing short straight lines. For straight lines, the stepper-coordinates is linear, so they don't need segmentation for the exactness of printing a long straight line.
                  For kinematics where stepper-coordinates are nonlinear, like Delta, polar, Scara, parallel scara, robots, segmentation is also necessary additionally to divide straight lines into segments, because the stepper-coordinates is nonlinear even for straight lines.
                  Your polar printer e.g. has one actuator rotating the plate: at the outer regions, the angle speed is higher than at the middle of the plate. This must be corrected while printing the line.
                  • CNCModeller
                    CNCModeller @JoergS5 last edited by CNCModeller
                    @joergs5 so what does the T variable refer to?
                    i.e. how is it used in the polar kinematics?
                    I'm getting good small features even with the larger 0.5mm t variable. I'm printing a 720 tooth GT2 pulley (2mm tooth pitch) and the tooth profile looks great. It's approximately 450mm in diameter.
                    I'm guessing the smaller model segmentation means that kinematics segmentation isn't applied due to the model segments being less than 0.5mm long.
                    Wanhao D4S: Duet2
                    • JoergS5
                      @cncmodeller I would propose testing different parameters with a line like so on your printer:
                      The line crosses or is near the center, so you'll see whether it is straight enough with low segmentation.
                      The teeth will be small, so you'll see no difference between different segmentation settings.
                      There may be limits of the segmentation in the firmware which I'm not aware of (minimum of T). But this is good to know when using Duet with a nano printer...
                      You have a fast Duet, so you can use high segmentation and check with M122, whether you touch any limits.
                      Your initial task was to speed up. In most cases, the reason is not the xyz speed of the actuators, but the maximum speed of the filament extrusion (the volume that can be heated up and extruded, the extruder stepper itself is fast enough) which limits the speed.
                      • CNCModeller
                        @joergs5 yeah I've hit the hot end thermal limit on my 0.6mm volcano where I'm getting temperature drops, however the new beta firmware has extruder temp feed forward so I'm hoping that'll give me some more head room. I'm already printing pla at 245c to get better thermal transfer.
                        Wanhao D4S: Duet2
