Solved 3.4.0 beta4 troubles
Two things happened after I uploaded 3.4.0 beta4 today. Previously with beta3 okay.
My config duet3 6HC + 1LC, SBC Pi4
When upgrading, the terminal asks if you want to upgrade the tool board. YES. It went without a error. But after the reboot when I check the M122 b121 the version was still the original (beta3). M997 B121 and then everything is OK.
after about 2 hours of printing, my filament was jamed (90% GCODE done). Magnetic sensor paused print, no problem. I corrected the error on the spool, moved the filament back and forth a few times and pressed the resume. The extruder moved to the place where printing was interrupted and nothing happened for about 5 seconds. Then the printer decided to make it home again, and it looked like GCODE had started from begin. Unfortunately, I couldn't research it anymore because I had to use the emergence button to avoid big crash.
I will try to repeat it and document more.
I tested again and happend again. Same problem. Print will restart from beginnig. It can also be seen in the percentage that is done. It starts from the beginning. Just press pause and resume. It also starts from the beginning. Something is wrong ...
Before anyone ask, here is pause.g and resume.g. Nothing special.
; pause.g ; called when a print from SD card is paused ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Apr 21 2021 11:35:56 GMT+0200 (Středoevropský letní čas) M83 ; relative extruder moves G1 E-10 F3600 ; retract 10mm of filament G91 ; relative positioning G1 Z5 F360 ; lift Z by 5mm G90 ; absolute positioning G1 X50 Y50 F6000 ; go to X=0 Y=0
; resume.g ; called before a print from SD card is resumed ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Apr 21 2021 11:35:56 GMT+0200 (Středoevropský letní čas) G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move G1 R1 X0 Y0 ; go back to the last print move M83 ; relative extruder moves G1 E10 F3600 ; extrude 10mm of filament
@petrkroupa said in 3.4.0 beta4 troubles:
I have just tested this and could not recreate the issue, going from 3.4b3 to 3.4b4. that said I did find that the firmware updates took longer than the apt command gave them to finish which may be the cause of the problem so I have reported it to @chrishamm.
Now looking at the second part of your report.
@petrkroupa Yes i can reproduce an issue with pause on my toolchanger using 3.4b4 in SBC mode. Thanks for reporting this.
@petrkroupa and @leobg This issue should be fixed in b5
https://forum.duet3d.com/topic/25510/software-bundle-3-4-0-b5-released
@t3p3tony I can confim, in beta5 pause\resume work with no problem. And update from b4 to b5 with no problem. Tool board was updated during update proces. Good work!
@petrkroupa thanks for confirming that has fixed the issue!
