    Solved D3 Mini + wont upgrade to Release 3.4.0 beta 4
    Firmware installation
    195
    • CNCModeller
      CNCModeller last edited by
      Hi All,
      I'm trying to upgrade my D3 Mini + to 3.4.0beta4 (https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.0beta4)
      I upload the firmware to the "system", "firmware directory" and then the updater runs, but when I check with M122 its still showing as installed on the board.
      "RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta3 (2021-08-24 14:08:24) running on Duet 3 Mini5plus WiFi (standalone mode)"
      I've tried twice now and done a hard reset in between, any thoughts?
      Cheers
      BPM
      Polar Printer Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      Wanhao D5S & K40 Laser, Duet2 TBD
      https://www.youtube.com/CNCModellerUK
      PetrKroupa 1 Reply Last reply Reply Quote 0
      • PetrKroupa
        PetrKroupa @CNCModeller last edited by
        @cncmodeller - Did you try M997?
        BigOne:Duet3 6HC +1LC + Rpi4, mosquito hotend, 400x400x420
        SmallOne : Duet3 6HC +1LC + Rpi4, mosquito hotend, 210x250x210
        Petr
        CNCModeller 1 Reply Last reply Reply Quote 0
        • CNCModeller
          CNCModeller @PetrKroupa last edited by
          @petrkroupa said in D3 Mini + wont upgrade to Release 3.4.0 beta 4:
          M997
          Thanks for the heads up @PetrKroupa , but still no dice!
          After posting I've noticed someone else has this issue so it might be something specific to this firmware.
          Wanhao D4S: Duet2
          PCR 1 Reply Last reply Reply Quote 0
          • PCR
            PCR @CNCModeller last edited by
            @cncmodeller do you have the .bin File on the duet?
            • CNCModeller
              CNCModeller @PCR last edited by
              @pcr the file in the firmware directory is dated as of today, its Duet3Firmware_Mini5plus.uf2 for the D3Mini.
              I've updated my CAN motor driver board with no problems.
              Wanhao D4S: Duet2
              • PCR
                @cncmodeller
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet3_SBCiap32_Mini5plus.bin
                Upload this to the sys and Firmware directory then Upload the Firmware again
                • CNCModeller
                  Tried that @pcr, still no dice...
                  Wanhao D4S: Duet2
                  • PCR
                    @cncmodeller can you downgrade to 3.3 and the. Upgrade
                    • CNCModeller
                      @pcr that's weird, downgrade to 3.3 then upgrade to 3.4b4 and it still shows b3...
                      very odd
                      Wanhao D4S: Duet2
                      • T3P3Tony
                        T3P3Tony administrators @CNCModeller last edited by
                        @cncmodeller maybe you have got the 3.4b3 uf2 by mistake?
                        www.duet3d.com
                        • CNCModeller
                          CNCModeller @T3P3Tony last edited by CNCModeller
                          @t3p3tony
                          Ah OK, just tried again. When I uploaded the 3.3 firmware it didn't take either... that explains it.
                          Is there any way to force a firmware update without using DWC? Or doesn't it make any difference?
                          Nb: I'm also on Duet Web Control 3.4.0-b4
                          Wanhao D4S: Duet2
                          • T3P3Tony
                            @cncmodeller send M997 from the console.
                            www.duet3d.com
                            • CNCModeller
                              @t3p3tony
                              Thanks Tony. I'd already tried that as a generic M997 no change. I'll try forcing the relevant filename next.
                              Wanhao D4S: Duet2
                              • T3P3Tony
                                @cncmodeller if that does not work then you can connect over USB, double tap the reset button and a drive will be created that you can drag the UF2 into.
                                www.duet3d.com
                                • CNCModeller
                                  @t3p3tony
                                  Still no dice, of note the SD came up as corrupted on my PC, so I repaired it with the windows tool.
                                  I've pulled the SD and placed the firmware in the root from here: https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0beta4/Duet3Firmware_Mini5plus.uf2
                                  I've then run M997 S0 P"0:/Duet3Firmware_Mini5plus.uf2"
                                  Unfortunately M122 still shows "RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta3 (2021-08-24 14:08:24) running on Duet 3 Mini5plus WiFi (standalone mode)" as does the DWC "settings", "machine specific" page.
                                  Is it worth reformatting and rebuilding the SD? Not sure where to go from here?
                                  Wanhao D4S: Duet2
                                  Dougal1957 1 Reply Last reply Reply Quote 0
                                  • Dougal1957
                                    Dougal1957 @CNCModeller last edited by
                                    @cncmodeller did you place the file in the /Firmware Folder or ROOT Root won't work with M997 but if you follow Tony's suggestion of connect by USB hit the reset twice should put it into Bootloader and pop up a Explorer window with 3 files in it then drop the firmware file into that drive and it should just upgrade
                                    • CNCModeller
                                      CNCModeller @Dougal1957 last edited by
                                      @dougal1957 Ah ok, I'll have to pull the board from its enclosure to connect to the usb port. Will look at that after work tonight.
                                      Many thanks
                                      Barry M
                                      Wanhao D4S: Duet2
                                      • T3P3Tony
                                        @cncmodeller before trying to remove the board, can you confirm what @Dougal1957 asked about the uf2 file in /firmware as opposed to /
                                        www.duet3d.com
                                        • CNCModeller
                                          @t3p3tony
                                          I've already tried running M997 with the firmware in the firmware folder, this time I used the specified location of the SD root i.e.
                                          I assume O is the SD root based on the M997 docs?
                                          I'm rooting for a right angle micro SD lead as I type so I don't have to pull the board.
                                          Wanhao D4S: Duet2
                                          • T3P3Tony
                                            @cncmodeller i assume you mean micro usb lead?
                                            www.duet3d.com
                                            CNCModeller 2 Replies Last reply Reply Quote 0
                                            • CNCModeller
                                              @t3p3tony said in D3 Mini + wont upgrade to Release 3.4.0 beta 4:
                                              Yup... having a bad day!
                                              Wanhao D4S: Duet2
                                              • CNCModeller
                                                @t3p3tony, the USB + double tap procedure worked! Albeit I had some issues along the way, see below.
                                                Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.0beta4 (2021-09-27)
                                                So some useful feedback for future me...
                                                Make sure you have the correct USB drivers installed... device manager should say: "Duet 3 motion control electronics"
                                                https://github.com/Duet3D/RepRapFirmware/blob/dev/Driver/WindowsDriverFiles.zip
                                                Long USB cables don't work for doing the double tap procedure... a short cable + powered USB extender works like a charm!
                                                Thanks for everyone's help, and now back to the main event!
                                                Cheers
                                                Barry M
                                                Wanhao D4S: Duet2
