    Unsolved Reset at reason: Stuck In Spin Loop
    Using Duet Controllers
    • Aitor
      Aitor last edited by
      Good morning,
      I have a machine that is constantly rebooting, sometimes just uploading files to the microSD card.
      I have done M122 and this is the result:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917NK-F23T0-6JTDJ-3S46L-TDADD
      Used output buffers: 3 of 24 (23 max)
      Static ram: 23876
      Dynamic ram: 75504 of which 0 recycled
      Never used RAM 12180, free system stack 184 words
      Tasks: NETWORK(ready,14.1%,247) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.7%,442) IDLE(ready,0.1%,29), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:47:50 ago, cause: software
      Last software reset at 2021-11-03 12:05, reason: StuckInSpinLoop, GCodes spinning, available RAM 12180, slot 0
      Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2000232c Task MAIN Freestk 764 ok
      Stack: 0042ae6f 004545d8 610f0000 3e7dff00 40dd4c00 369dc3a0 3edbc06f 3331bb4c 40000000 b5ddd98d 388ab355 bb360b61 3e2aaaab 3f800000 3f800000 4205adc8 4354c416 3e7dff00 3e7dff00 60000010 00000000 00000000 0042ae6f 00000001 00006240 00000000 20000c60
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 37.2, current 39.3, max 39.9
      Supply voltage: min 23.9, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/6, heap memory allocated/used/recyclable 2048/62/0, gc cycles 0
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-11-03 12:54:02
      Slowest loop: 212.43ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 52.5ms, write time 78.7ms, max retries 3
      === MainDDARing ===
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.5
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 195.38ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.26
      WiFi MAC address 84:0d:8e:b3:06:d4
      WiFi Vcc 3.38, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 24392
      WiFi IP address 192.168.1.230
      WiFi signal strength -53dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      Can you guide me to what might be going on or what to look for?
      Previously I was working with version 3.1.1 on this machine and the same thing happened to me.
      I'm checking the wiring for shorts or shunts, but so far I haven't found anything.
      The configuration of this machine is identical to others that work perfectly.
      Thank you, best regards
      gloomyandy T3P3Tony 2 Replies Last reply Reply Quote 0
      • gloomyandy
        gloomyandy @Aitor last edited by
        @aitor said in Reset at reason: Stuck In Spin Loop:
        Might be worth trying a different SD card. You shouldn't really be getting retries.
        • T3P3Tony
          T3P3Tony administrators @Aitor last edited by
          @aitor thats a good spot by @gloomyandy if you could try a know good SD card to rule that our.
          www.duet3d.com
          Aitor 1 Reply Last reply Reply Quote 0
          • Aitor
            Aitor @T3P3Tony last edited by
            Morning @t3p3tony and @gloomyandy
            Ok, I'll try it today and let you know
            Thanks
            • Aitor
              Aitor @Aitor last edited by
              Good morning @t3p3tony and @gloomyandy
              I changed the SD card and the same thing happened, this time it did reboot during a print once.
              Maybe something else happened as it says that it was restarted 95h ago but the printing stopped.
              I have activated an M929 eventlog to see if it gives me more information.
              This was the result of M122:
              16/11/2021 15:15:32 M122
              Used output buffers: 3 of 24 (24 max)
              Static ram: 23876
              Never used RAM 12180, free system stack 168 words
              Tasks: NETWORK(ready,14.1%,217) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,364) MAIN(running,85.8%,461) IDLE(ready,0.0%,29), total 100.0%
              Owned mutexes:
              Last reset 95:21:31 ago, cause: software
              Last software reset at 2021-11-12 15:53, reason: StuckInSpinLoop, GCodes spinning, available RAM 11972, slot 1
              Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200032b4 Task NETW Freestk 403 ok
              Stack: 0042ae6f 004545fc 410f0000 3e800000 412586e8 42263771 3edbc06f 3331bb4c 40000000 b5ddd98d 388ab355 bb360b61 3e2aaaab 3f800000 00000000 40951efe 457f5a39 7f7fffff 3e800000 80000010 00000000 00000000 0042ae6f 00000001 0025bc42 00000000 20000818
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 35.1, current 35.6, max 35.6
              Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
              Date/time: 2021-11-16 15:15:13
              Slowest loop: 3.60ms; fastest: 0.17ms
              === Storage ===
              SD card longest read time 1.0ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              === AuxDDARing ===
              Heater 1 is on, I-accum = 0.4
              Segments left: 0
              === Network ===
              Slowest loop: 201.69ms; fastest: 0.08ms
              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
              • WiFi -
                Failed messages: pending 0, notready 0, noresp 1
                WiFi flash size 4194304, free heap 24632
                WiFi signal strength -51dBm, mode 802.11n, reconnections 0, sleep mode modem
                Socket states: 4 0 0 0 0 0 0 0
              • Topic has been marked as a question  Phaedrux Phaedrux
