Solved Z map with no probe
No. I simply copied the files from the other printer with Quad Z and uploaded to this machine, then tweaked as I went.
@fcwilt where are you getting Duex 2 from? His M122 says Duex 5.
If you're willing to take the plunge to RRF3 now might be the ideal time to do, though it would mean starting with a fresh config file set. Though you'd be able to generate a good starting base to work from with the online config tool.
If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
That will get your firmware and DWC up to date.You can see the change logs here:
https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.xFor your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
https://configtool.reprapfirmware.org/StartBackup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
These documents will come in handy during the conversion.
https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
https://duet3d.dozuki.com/Wiki/Gcode -
@droftarts said in Z map with no probe:
I didn't see the output from M122. His config file comments mentioned Duex 2 and I asked him to verify if that was true. He said it was. I guess he was confused.
I want to thank you all very much. I ended up deleting everything related to probe and G30 and now while Z motion homes rrrreeeaaallllyyyyy slow, I was able to make some calibration prints to dial in the machine.
This is a great community and I appreciate you time!
