    Extruder engines do not work
    • Kitkat
      Kitkat last edited by
      Hello
      For 2 weeks my printer with Duet Wifi finished. And he really works very well. But since 4 days both extruder engines Drive 3 / Drive 4 (Nema 17HS08-1004S) work no longer. Connected to X Drive 0 and Y Drive 1 they work. They are also not heated or make noises. The chips have no damage on the surface. All cables were reconnected with plugs.
      The diagnosis is "temperature-warning standstill". What can it mean?
      Strangely, it was only printed with Drive 4. The printer is operated with 24V. Where is the error?
      Greetings from Hamburg
      Used output buffers: 1 of 32 (9 max)
      Static ram used: 20320
      Dynamic ram used: 73104
      Recycled dynamic ram: 784
      Stack ram used: 968 current, 3168 maximum
      Never used ram: 33696
      Last reset 00:46:29 ago, cause: power up
      Last software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
      Spinning module during software reset: GCodes, available RAM 33576 bytes (slot 0)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 44.9, current 50.9, max 54.4
      Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0
      Driver 0: stalled standstill
      Driver 1: stalled standstill
      Driver 2: stalled standstill
      Driver 3: temperature-warning standstill
      Driver 4: temperature-warning standstill
      Date/time: 2017-09-24 22:21:04
      Slowest main loop (seconds): 0.009888; fastest: 0.000000
      MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 20, completed moves: 20
      Bed compensation in use: none
      Probe change coordinates:
      Bed heater = -1, chamber heater = -1
        The temperature warning means that the drivers are hot, but not yet hot enough to trigger thermal shutdown. In normal operation, it will occur if you use a motor current exceeding about 2.0A without using a fan to cool the Duet.
        What current do you have the extruder motors set to?
        • Kitkat
          The current is 800 mA. I've removed all the cables it is still "temperature-warning standstill". And only both extruder chips will be very hot. Maybe both chips are damaged.
            Please ask your supplier to repair or replace your Duet.
