reprapfirmware update hanging
I'm doing a yum upgrade, and everything worked, except the reprapfirmware:
pi@duet3:~ $ sudo apt upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: libllvm8 libxss1 rpi-eeprom-images Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] y Setting up reprapfirmware (3.4-b7-2) ... Progress: [ 33%] [###################.......................................]
Here's the output from M122, am I making too large a jump in versions or something?
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.01-RC2 running on Duet 3 MB6HC Board ID: 08DJM-956L2-G43S8-6J9DA-3SD6J-1V3QF Used output buffers: 1 of 40 (4 max)
@bridgier said in reprapfirmware update hanging:
3.01-RC2
I think your best bet is to manually flash the firmware to 3.3 with BOSSA and then try the update/upgrade again. Some of the early beta/release candidates didn't update cleanly. Going to a stable release version first should fix it.
Also I think in your case you would need to go to 3.3 first anyway before you can go to 3.4 at all.
@phaedrux Yeah, that's what I was afraid you'd say
Now I've got to disassemble the printer to get access to the usb port...
You might be able to use this method via DWC to get you to a stable release.
@phaedrux IIRC, pre 3.01b9 needs to use bossa. Could be wrong though
