Retraction/un-retraction events
Hello everyone, I'm using a duet wifi on my Tevo Little Monster and I'm getting a retraction/un-retraction event on my console, I don't know why... maybe because it conflicts with my slicer settings or something? I'm using Cura and I have firmware retraction turned off.
If anyone know why this is happening please let me know.
Thanks!
Check your gcode. It looks like it's sending M207 and it's reporting the default firmware retraction values.
https://duet3d.dozuki.com/Wiki/M207
Do you have Cura set to use RepRap gcode flavor?
I checked the GCode and indeed is sending some M207
Here's the start of the code:
M207 X30
G1 F600 Z0.48
G0 F3600 X-27.579 Y5.831 Z0.48
M207 X20Yes I have Cura set up with reprap gcode flavor, what should I do?
@empana said in Retraction/un-retraction events:
Are you sure it's reprap and not repetier or something?
https://reprap.org/wiki/G-code#M207:_Firmware_dependent
Far as I can tell Repetier is the only one that uses M207 X as syntax for changing jerk.
Can you share that gcode file?
Oh god I was wrong, the flavour was repetier... I feel too dumb hahahaha
Well changed it to reprap and it solved the issue, thanks for the help phaedrux!!!
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
