    What's wrong with my script
    • zapta
      zapta last edited by zapta
      I have a macro file with the script below. When I run it I expect a slow extruder movement over 24 seconds but instead the extruder moves fast for a second or less and the two messages are printed almost at the same time.
      What am I missing?
      Board: Duet 3 Mini 5+ (Mini5plus)
      Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.0beta5 (2021-10-12)
      M302 P1      ; allow  cold extrusion.
      M83          ; set extruder to relative mode
      echo "Start"
      G1 E60 F150  ; Extrude 60mm at 2.5mm/sec
      echo "Done"
      M82          ; set extruder to abs mode
      • deckingman
        deckingman @zapta last edited by
        @zapta Try putting M400 after the G1 command.
        zapta 1 Reply Last reply Reply Quote 0
        • zapta
          zapta @deckingman last edited by
          Thanks. M400 after G1 didn't make a change.
          echo "Start"
          M400
          echo "Done"
          fcwilt 1 Reply Last reply Reply Quote 0
          • mikeabuilder
            mikeabuilder last edited by mikeabuilder
            @zapta, I think inserting a wait before the done message - P400 (or a G4 P0) doing nothing makes sense because your description is that the extrude is happening too fast, not that the message is printed before the extrude completes.
            Normally, the F parameter is used to describe the speed of movement between two points, while extruding E (mm) of filament along the path. I'm not sure how F works if there is only an E parameter. Based on your description of what you saw, maybe F with only E is interpreted as mm/sec, not mm/min. If that were the case, your 60mm of filament would extrude in 2.5seconds.
            • fcwilt
              fcwilt @zapta last edited by
              @zapta
              As a test insert a G1 Xaaa Ybbb command to move to some start point.
              Then modify your existing G1 to include Xccc Yddd where ccc and ddd will move to some end point.
              See how that changes the extruder behavior.
              • zapta
                zapta @fcwilt last edited by
                Thank you everybody for the suggestion. The script works now. The trick was to separate the speed and the extrusion to two G1 commands. Not sure if this is intended or a bug in the version I am using.
                echo "Start"
                G1 F150      ; Set extrusion speed to 2.5mm/sec
                G1 E60       ; Extrude 60mm.
                M400         ; Wait for motion to end.
                echo "Done"
