Unsolved [3.4.1-pre2] Issue with extrusion
There is an issue with extruding from Extrusion panel on the PanelDue. The first time you enable the hot end heater and extrude from the Extrusion panel, the extruder moves at about 200mm/s (guessing) - even when selecting 2mm or 5mm. Selecting the same move again results in the correct speed. It is repeatable by turning off the heater, turning it back on, and then extruding - and only ever happens the first time.
This is happening with Duet 3/SBC running 3.4-rc2. Will update to 3.4 stable and test soon, but I haven't been able to get it to happen from DWC, so I'm thinking it's something in the PanelDue.
Please let me know if you need more info or a quick video of the issue.
oozeBot
This is still occurring with 3.4 stable. I believe it must be something in the PanelDue's code but have not had time to review it.
do you experience this problem with DWC as well?
