    Solved New Duet2 WIFI no WIFI
    • Highländer1972
      Highländer1972 last edited by
      Try to connect my new Duet 2 WIFI blue Led at WIFI module does not come on. I cross checked SSID and Password with my other Duet Board there it works without problem.
      m997 s0
      Shutting down USB interface to update main firmware. Try reconnecting after 30 seconds.<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>
      m115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2<LF>ok<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>
      m997 s1
      Trying to connect at 230400 baud: success<LF>Erasing 4096 bytes...<LF>Erasing 212992 bytes...95% complete<LF>Upload successful<LF>ok<LF>WiFi module started<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>
      m552 S-1
      WiFi module stopped<LF>ok<LF>
      m552 s0
      M587 S"FRITZ!Box 7530 DL" P"////****"
      ok<LF>
      m552
      WiFi module is idle<LF>ok<LF>
      m552 s1
      Anything else I could try.
      Regards,
      Stefan
        Is the router creating a 2.4ghz network?
        If you send M587 by itself does it list the correct network?
        Highländer1972 1 Reply Last reply Reply Quote 0
        • Highländer1972
          Highländer1972 @Phaedrux last edited by
          @phaedrux
          Yes the Network is correctly listed and providing 2,4 GHz. It is working with to other Duet2WIFI.
          I wonder that blue Led is not comming on when sending m552 s1. On my other Board it comes on blinking even when the network is not available.
          Should I try latest firmware?
          Stefan
            When and where did you purchase the Duet?
            How does the soldering look on the wifi module itself?
            • Highländer1972
              @phaedrux
              Thank you for your support I could solve the problem.
              I just used the comand M587 as it worked with my old DUET2wifi Firmware 2.. with intial ssid and network key with slash as seperator.
              With the new Firmware (updated now no to 3.4.0) I have to use the user assigned network name and key without seperators.
              Instead of
              M587 S"FRITZ!Box 7530 DL" P"1234/1234/1234/1234"
              M587 S"StefanHeim" P"1234123412341234"
              Regards,
              Stefan
              • Topic has been marked as a question  Phaedrux Phaedrux
              • Topic has been marked as solved  Phaedrux Phaedrux
