    Solved Tool 1 offset not being applied in 3.4
    161
    • Tinchus
      Tinchus last edited by
      Hello . I have upgraded from 3.3 stable version to 3.4 stable, and my T1 tool is not receinving its offset now. When I issue a T1 command, the tool changes and it is active, but the offset is not applied, has anything changed in 3.4 version with the G10 command
        dc42 administrators @Tinchus last edited by dc42
        @tinchus there has been no intentional change in RRF 3.4 that I think explains what you have reported.
        Please use the Object Model Browser in DWC to check that the tool offsets have been set correctly.
        Tinchus 2 Replies Last reply Reply Quote 0
        • Tinchus
          Tinchus @dc42 last edited by
          @dc42 Offset are there. I can see the Y=-66.95 X=0 Z=-1.6
          • Tinchus
            @dc42 I have just noticed: the X and Y offsets are being applied, I can see the movments corectio when issuing a T1 command, it is the Z offset the one not being executed
              @tinchus please see the RRF3.4 upgrade notes. After a tool change the original Z position is no longer restored because too many users complained that it was not appropriate on their systems. You can restore the original Z position taking account of the Z offset by adding G1 Z0 R2 Fxxx at the end of the tpost file, where xxx is an appropriate feed rate for the Z axis.
              Tinchus 1 Reply Last reply Reply Quote 0
              • Tinchus
                @dc42 Ok, my bad for not reading that. Doc says:
                we suggest you add command G1 R2 X0 Y0 Z2 Fxxx followed by G1 R2 Z0 Fxxx to the end of your tpost#.g files,
                Why the second line of command?
                gloomyandy 1 Reply Last reply Reply Quote 0
                • gloomyandy
                  gloomyandy @Tinchus last edited by
                  @tinchus That's doing the move in a slightly safer/better way by splitting it into two steps. The first moves to the saved X/Y point but 2 mm above it and the second move will then move vertically down to the full X/Y/Z point. By doing it that way you are less likely to hit the part or cause scarring etc by moving over it with say a nozzle that has filament built up on it.
                  • Tinchus
                    Question solved, thank you very much for the help
                    • Topic has been marked as a question  dc42 dc42
                    • Topic has been marked as solved  dc42 dc42
