    Toolboard + NO NPN probe
    922
    • tecnoundefined
      tecno
      I have had a mishap with IR probe and need to replace it fast and only suitable I have is a inductive NO.
      Plan is to take 24V from incoming power to run this probe. Is the config lines OK?
      M574 X1 S1 P"!121.io2.in" ; configure active-high endstop for low end on X via pin ^io3.in
      M574 Y1 S1 P"!io0.in" ; configure active-high endstop for low end on Y via pin ^io0.in
      M574 Z0 S2 P"!121.io1.in" ;
      M558 C"!121.io1.in" P5 H10 F120 T8000 ; F120
      G31 P50 X0 Y20 Z0 ;3.490
      M557 X5:340 Y25:400 P4:4 ; define mesh grid
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @tecno
        Realized that io1 on toolboard is only 3.3V tolerant so I changed to io0.
        But still no trigger from 'probe'. Must be something I am missing in config, pleas help.
          jay_s_uk @tecno
          @tecno you can't map a pin twice. get rid of the M574 Z0 line
          tecnoundefined 2 Replies Last reply Reply Quote 0
          • tecnoundefined
            tecno @jay_s_uk
            @jay_s_uk
            Morning, so it is OK with IR but not switch. Still learning 🙂
            • tecnoundefined
              tecno @jay_s_uk
              @jay_s_uk
              Did get rid of the line.
              So what is wrong?
              ; M574 Z1 S1 P"^!121.io0.in" ;
              M558 C"^!121.io0.in" P5 H10 F120 T8000 ; F120
              Greatful to get some help here.
                jay_s_uk @tecno
                @tecno might be a good idea to post your whole config and an output of M98 P"config.g"
                • tecnoundefined
                  tecno @jay_s_uk
                  @jay_s_uk
                    jay_s_uk @tecno
                    @tecno well there you go. use P8 and not P5
                    • tecnoundefined
                      tecno @jay_s_uk
                      @jay_s_uk
                      a61bae5c-9ac9-475e-a5c0-a73e2738dc4c-config.g
                      Hard DIVE into the bed, led on probe lights up but no reaction to that
                        jay_s_uk @tecno
                        @tecno maybe you don't need the pullup?
                        best to check these things far away from the bed rather than relying on that as a last resort
                        • tecnoundefined
                          tecno @jay_s_uk
                          @jay_s_uk
                          M558 C"!121.io0.in" P8 H10 F120 T8000
                          With probe not triggered Prove value is 0 triggered is 0
                          If I set probe not inverted Probe value is 1000 triggered still 1000
                          No change whatever I try
                          jay_s_ukundefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
                            jay_s_uk @tecno
                            @tecno maybe you need a diode as detailed here https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting#npn-output-normally-open-inductive-or-capacitive-sensor?
                            other than that, no idea
                            • infiniteloopundefined
                              infiniteloop @tecno
                              @tecno said in Toolboard + NO NPN probe:
                              Either you have no signal on the pin, or it is constantly tied to 3.3V by the probe. Check function of the probe stand-alone with a multimeter: What voltages do you read when the probe is triggered/untriggered?
                              A third possibility might be the port being defective, but first, check your probe signal.
                              • tecnoundefined
                                tecno @infiniteloop
                                @infiniteloop
                                NPN and no 3.3V ! Vin as these need 6-30V
                                Vin non triggered = out Vin
                                Triggered = out under 0.6V
                                So probe is OK
                                Looks like the Tollboard is busted again 😞
                                infiniteloopundefined 1 Reply Last reply Reply Quote 0
                                • tecnoundefined
                                  tecno @jay_s_uk
                                  @jay_s_uk said in Toolboard + NO NPN probe:
                                  Select mode 5 (P5) in the M558 command. Invert the probe output From the manual you linked !
                                    jay_s_uk @tecno
                                    @tecno https://docs.duet3d.com/en/User_manual/RepRapFirmware/CAN_limitations
                                    only P8 and P9 can be used on CAN boards
                                    • tecnoundefined
                                      tecno @jay_s_uk
                                      @jay_s_uk
                                      Doh... too many variables so confusing it is.
                                      How can i check port that it is working? Short GND to INP or 5V?
                                      Set it as P8 so I can see Probe value 0 or 1000
                                        infiniteloop @tecno
                                        Do I understand this right: The signal has 6-30V non-triggered?
                                        • tecnoundefined
                                          tecno @infiniteloop
                                          @infiniteloop
                                          Yes
                                            infiniteloop @tecno
                                            Yes
                                            Then you've fried the port. 😢
