    Flashing panel
    • Adamfilip
      Adamfilip last edited by
      Ive noticed that my 7" PanelDue has started flashing, on and off every second.. since around the time i installed 1.19
      not sure what to do about it.
        If this is when the Duet is powered by USB only, that's not unusual, because most computer USB ports can only supply about 500mA and a Duet with 7" Panel Due needs more than that.
        • Adamfilip
          It is powered using the 4 wire connector to the DuetWifi
          was working fine since i got it until. Around the time that 1.19 came out.
            Yes, but are you powering the Duet from a USB cable to a PC, or with 12V or 24V power?
