    Solved Stepper Motors Not Working
    • TRATOON
      TRATOON last edited by
      Hello, I installed a Duet 2 WiFi on my Ender 5 Plus and everything was working fine. Yesterday, I cleaned up the wiring a little bit and now when I home an axis, the motors move roughly for about a second, and then I get error: "driver 1 warning: phase a may be disconnected." I checked all the wiring and phases are continuous and in the right spots.
      alankilian 1 Reply Last reply Reply Quote 0
      • alankilian
        alankilian @TRATOON last edited by
        @tratoon
        Did you happen to tie all the wiring together in a bundle with wire ties?
        Sometimes that can cause issues.
        Each stepper motor wire bundle should be separated from all other wiring.
        TRATOON 1 Reply Last reply Reply Quote 0
        • TRATOON
          TRATOON @alankilian last edited by
          @alankilian I used zip-ties to tie them with the frame and they are all separate, except for when they enter the control box, as then, all four stepper wires are together.
          • Topic has been marked as a question  TRATOON TRATOON
          • TRATOON
            TRATOON last edited by TRATOON
            @alankilian The Y Motor works but it buzzes. The X Motor works fine. Both Z Motors are spinning in same direction but make sounds and act like the Y motors. I unplugged then re-plugged, and now Y works fine but X just buzzes
            • Topic has been marked as solved  TRATOON TRATOON
