Euclid probe and Z=0 datum
I recently installed a Euclid probe (dock-able probe similar to klicky probe). However I constantly get
Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
My last G32 results were
16 points probed, min error -0.318, max error -0.122, mean -0.206, deviation 0.055 Height map saved to file 0:/sys/heightmap.csv Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh. Leadscrew adjustments made: -0.200 -0.200 -0.205, points used 3, (mean, deviation) before (-0.202, 0.002) after (0.000, 0.000)
My config.g
M80 C"pson" ; Turns on the ATX power supply G4 S1 ; Wait for tool board G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M669 K1 ; select CoreXY mode M955 P20.0 I14 ; specify orientation of accelerometer(+Y,-X) on Toolboard 1LC with CAN address 20 ; ====================== Network =========================== ; not supported on Duet 3 with SBC ; ======================= Drives =========================== M569 P20.0 S0 D3 ; physical drive 0.0 goes backwards-Extruder M569 P0.0 S0 D3 ; physical drive 0.1 goes backwards-X stepper M569 P0.1 S0 D3 ; physical drive 0.2 goes backwards-Y stepper M569 P0.3 S0 ; physical drive 0.3 goes backwards-Z left stepper M569 P0.4 S0 ; physical drive 0.4 goes backwards-Z right front stepper M569 P0.5 S0 ; physical drive 0.5 goes backwards-Z right rear stepper M584 X0.0 Y0.1 Z0.3:0.4:0.5 E20.0 ; set drive mapping Z3=Left center, Z4= Right front, Z5=Right rear ; ===================== Drive Settings ===================== M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation XY .9 degree ZE 1.8 degree M92 X200.00 Y200.00 Z400.00 E707.00 ; set steps per mm XY .9 degree ZE 1.8 degree - NF-Sunrise Maybe 683 M203 X5000.00 Y5000.00 Z800.00 E7200.00 ; (mm/min) Set maximum speeds mm per minute/60=mm per second M201 X5000.00 Y5000.00 Z800.00 E5000.00 ; (mm/second^2) Set per-axis and extruder print accelerations M204 P2000 T8000 ; (mm/second^2) Set print and travel accelerations M566 X2000.00 Y2000.00 Z300.00 E5000.00 ; (mm/min) Set maximum instantaneous speed changes M906 X1600 Y1600 Z1400 E900 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S120 ; Set idle timeout ; ================ Independent Z Leveleing ================= M671 X-9.0:289:289 Y139.5:37.0:242.0 S10 ; leadscrew pivot point: M557 X30:245 Y50:225 P4 ; Defines the grid Mesh Bed probing. ; ===================== Axis Limits ======================== M208 X-3 Y-10 Z0 S1 ; set axis minima M208 X275 Y277 Z240 S0 ; set axis maxima ; ======================= Endstops ========================= M574 X1 S1 P"20.io1.in" ; configure active-high endstop for high end on X via pin i01.in M574 Y2 S1 P"0.io2.in" ; configure active-high endstop for high end on Y via pin i02.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ;M591 D0 P1 C"20.io3.in" S1 ; configure filament runout sensor for high end on extruder drive 0 via pin i03.in ; ======================== Z-Probe ========================= M558 P8 C"^20.io0.in" H5 F250 T10000 ; set Z probe type and the dive height + speed G31 P500 X0.00 Y51.00 Z6.600 ; set Z probe trigger value, offset and trigger height ; ======================== Heaters ========================= M308 S0 P"0.temp0" Y"thermistor" A"Bed" T100000 B4725 C0.0000000706 ; configure sensor 0 as thermistor on pin temp0 M308 S1 P"20.temp0" Y"thermistor" A"Hotend" T100000 B4680 C6.455513e-8 ; configure sensor 1 as thermistor on pin temp1-Matrix M950 H0 C"0.out0" T0 ; create bed heater output on out0 and map it to sensor 0 M950 H1 C"20.out0" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H0 R0.290 K0.119:0.000 D29.94 E1.35 S1.00 B0 ;Set PID for bed heater POST RRF 3.4 M307 H1 R2.258 K0.262:0.297 D6.30 E1.35 S1.00 B0 V24.2 ;Set PID for bed heater POST RRF 3.4 M140 H0 ; map heated bed to heater 0 M143 H0 S100 ; set temperature limit for heater 0 to 100C M143 H1 S260 ; Set temperature limit for heater 1 to 260C M308 S10 Y"mcu-temp" P"0.mcu-temp" ; defines sensor 10 as MCU temperature sensor ; ========================= Fans =========================== M950 F0 C"20.out1" Q50 ; create fan 0 on pin out9 and set its frequency M950 F1 C"20.out2" Q50 ; create fan 0 on pin out9 and set its frequency M106 P0 C"Tool Fan" H1 T40 ; set fan 0 value. Thermostatic control is turned on M106 P1 C"Layer Fan" S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; ======================== Tools =========================== M563 P0 D0 H1 F1 ; define tool 0 G10 P0 X0 Y0 Z0 R0 S0 ; set tool 0 axis offsets ; ===================== Custom settings ==================== M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons ; ====================== Miscellaneous ===================== M575 P1 S1 B57600 ; enable support for PanelDue M575 P2 S1 B57600 ; enable support for BLV NeoPixels M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss M950 J1 C"!0.io3.in" ; Create GPIO pin for On button wired NO M581 T2 P1 S1 R0 ; T2-Run Trigger 2; P1-J1; S1-When button pressed; R0-trigger any time M950 J2 C"!0.io4.in" ; Create GPIO pin for On button wired NO M581 T3 P2 S1 R0 ; T3-Run Trigger 3; P2-J2; S1-When button pressed; R0-trigger any time M582 T3 ; when triggered run trigger3.g
bed.g
M561 ; clear any bed transform G91 ; relative positioning G1 H2 Z5 ; lift Z relative to current position G1 H1 X-300 Y300 F15000 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-300 F15000 ; home X axis G1 H1 Y300 F15000 ; home Y axis G1 X5 Y-5 ; go back a few mm G1 H1 X-5 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y300 F360 ; then move slowly to Y axis endstop G90 ; absolute positioning echo "Undock Probe" if sensors.probes[0].value[0]!=1000 ; if sensor is value other than 1000 do this ; uncomment next line to echo the probe deploy state ; echo "deployuser token = " ^sensors.probes[0].deployedByUser ; echo "Probe State = " ^sensors.probes[0].value[0] abort "deployprobe start value Probe already picked up. Manually return probe to the dock" if !sensors.probes[0].deployedByUser ; If the probe is not deployed, deploy it M401 ; Deploy probe G1 X150.0 Y90.0 F15000 ; go to first probe point G30 ; home Z by probing the bed G30 P0 X5 Y130 F300 Z-99999 ; Probe near left lead screw position X0 Y137.5 G30 P1 X270 Y40 F3000 Z-99999 ; Probe near right rear lead screw position X335 Y10 G30 P2 X270 Y245.0 F6000 Z-99999 S3 ; Probe near right rear lead screw position X335 Y265 G1 X150.0 Y90.0 F15000 ; go to first probe point G30 ; home Z by probing the bed G29 S0 ; Probe the bed, save the height map, and activate mesh bed compensation M400 ; wait for move to finish M402 ; dock probe
deployprobe.g
echo "Undock Probe" if !move.axes[0].homed || !move.axes[1].homed ; If the printer hasn't been homed, home it M98 P"0:/sys/homexy.g" ; uncomment next line to echo the probe deploy state ; echo "Object Model Deployuser token =" ^sensors.probes[0].deployedByUser ; uncomment next line to echo the probe value ; echo "Probe Value =" ^sensors.probes[0].value[0] if sensors.probes[0].value[0]!=1000 ; if sensor is value other than 1000 do this ; uncomment next line to echo the probe deploy state ; echo "deployuser token = " ^sensors.probes[0].deployedByUser ; echo "Probe State = " ^sensors.probes[0].value[0] abort "deployprobe start value Probe already picked up. Manually return probe to the dock" ; if we're here we know it's becasue the above is true which I assume is because you have an NC switch as a probe. ; echo "Passed first logic test to deploy probe" echo "Probe Pickup macro running" G0 X272 Y260 F3000 ; move to re-entry position M400 ; wait for moves to finish G0 X272 Y277 F300 ; move to Preflight Position G4 P500 ; pause 0.5 seconds M400 ; wait for moves to finish G0 X240 Y277 F300 ; move to Dock Side dock location M400 ; wait for moves to finish echo "Probe Pickup complete"
retractprobe.g
G0 X200 Y277 F3000 ; move to ready position M400 ; wait for moves to finish G0 X240 Y277 F3000 ; move to the entry position for the dock M400 ; wait for moves to finish G0 X272 Y277 F300 ; move into the dock position M400 ; wait for moves to finish G4 P250 ; pause 250 usecs G0 X272 Y240 F300 ; move to the side adjacent to the dock swiping the probe off G0 X150 Y150 F6000 ; move to the side adjacent to the dock swiping the probe off M400 ; wait for moves to finish echo "Probing complete"
My current setup
Duet 3 clone with RRF 3.4
24v PSU
Duet tool board v1.2
RPI4 on it's own dedicated PSU
5v PSU powering a latching relay and PSON to the Duet clone. The latching relay closes the neutral circuit for the main 24v PSU -
@dhusolo You need to home Z with the probe.
@stephen6309 It is homing Z with the probe. I actually figured it out. I had to add S-2 to both G30 commands in bed.g
@dhusolo said in Euclid probe and Z=0 datum:
You only have a single tool configured. With a single tool you shouldn't need to use G30 S-2. If you do something else is not right.
Just FYI:
- You don't need to use M400 between G0 moves.
- You don't need to use M400 after G29 S0.
Just out of curiosity:
- Why do you have the G4 commands when deploying/retracting the probe?
- Did you verify that a single bed leveling pass is sufficient to always level the bed?
Thanks much.
@fcwilt @fcwilt I used the macro templates from the Euclid probe website.
I have a railcore 250zl bed with independent leveling with kinematic mounts. I don't really have to deal with bed droppage too much. After I built it I ran numerous rounds of leadscrew leveling and the values were very consistent.
I've never had to use G30 S-2. I wasn't sure if it was because of the Euclid probe, a firmware issue, config issue or what the deal is. I've never had this happen before.
OK - I will check them out and talk with the author.
Good to know.
Well something is not configure correctly and it is not related to the Euclid probe.
When you used a plain G30 what was the result the led you to try G30 S-2?
Thanks.
@fcwilt G30 S-2 sets Z0 where the probe triggered. Probes don't trigger the same distance when the nozzle hits the bed, unless the hotend triggers the probe.
@fcwilt My first post has all the data. I just ran G32 again and this is the result.
Leadscrew adjustments made: 0.048 0.048 0.060, points used 3, (mean, deviation) before (0.052, 0.006) after (-0.000, 0.000) 16 points probed, min error -0.080, max error 0.108, mean 0.023, deviation 0.050 Height map saved to file 0:/sys/heightmap.csv
@stephen6309 said in Euclid probe and Z=0 datum:
S-2 sets the Z offset of the current tool. There is no reason to do that when there is only one tool as the relationship of the tool to the nozzle is fixed.
G30 alone sets the Z axis position to whatever the Z probe Z Trigger Height parameter is. This is intended to insure the Z=0 position of the tip of the nozzle is correct. If the Z Trigger Height parameter is wrong then Z=0 will be off.
Aside from not using very many points that heightmap looks OK.
Are you using the left, front grid point to set the Z=0 Datum?
@fcwilt No I use bed center for Z=0 Datum. That's the way I've always done it.
That's fine - that is what I do.
Try specifying a 3x3 grid or a 5x5 grid. The goal is to have the XY position of the center grid point match the XY position used for setting the Z=0 Datum.
If all is good the center most point should be reported as 0 deviation.
@fcwilt I went with a 5x5 grid and this is the result
Leadscrew adjustments made: -0.197 -0.156 -0.063, points used 3, (mean, deviation) before (-0.142, 0.055) after (0.000, 0.000) Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh. 25 points probed, min error -0.242, max error -0.005, mean -0.139, deviation 0.059
Did you determine the XY position of the center point of the grid and use that as the probe XY position when doing the G30 before creating the height map?
Remember when setting the XY position of the probe you have to take into account the XY offsets of the probe.
