The printer is trying to move outside of the work area
I have a Cartesian kinematics printer with X-axis endstop at the minimum end and Y-axis endstop at the maximum end.
Electronics is a duet 2 wifi. In config, I have set:M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
When I manually control the movement of individual axes, everything works as it should. X + 10 moves the carriage to the right and Y + 10 moves the bed towards me.During homing, the carriage and the bed normally approach the limit switches and it seems to me that they are working properly. The Y axis limit switch works rather because when I press the limit switch and check the status of M119, it shows:
As I understand it, after homing, the beginning of XY is in the lower left corner of the bed. However, when it generates a program in Cura and I run it on the printer, it wants to go forward beyond the Y axis up after homing. I do not understand why. I include the initial part of the code.
;FLAVOR:RepRap ;TIME:12744 ;Filament used: 12.4797m ;Layer height: 0.2 ;MINX:62.2 ;MINY:62.2 ;MINZ:0.3 ;MAXX:177.8 ;MAXY:177.8 ;MAXZ:100.1 ;Generated with Cura_SteamEngine 5.0.0 T0 M190 S60 M104 S200 M109 S200 M82 ;absolute extrusion mode G28 ;Home G1 Z15.0 F6000 ;Move the platform down 15mm ;Prime the extruder G92 E0 G1 F200 E3 G92 E0 M83 ;relative extrusion mode G1 F1500 E-6.5 ;LAYER_COUNT:500 ;LAYER:0 M107 G0 F3600 X69.942 Y70.755 Z0.3 G0 X63.804 Y80.699 ;TYPE:SKIRT G1 F1500 E6.5 G1 F900 X63.963 Y80.264 E0.02311 G1 X64.395 Y79.181 E0.05817 G1 X64.569 Y78.778 E0.0219 G1 X65.059 Y77.726 E0.0579 G1 X65.266 Y77.315 E0.02296
I'm not sure, but I guess it happens in this line.
I also tried to change the axis limit to be smaller or larger than the bed size, but the same thing still happens.
; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X240 Y240 Z230 S0 ; set axis maxima
What am I doing wrong ?
@cossack if its a moving bed, when its at the back and triggering the endstop, that should be set to be the axis minima not the maxima, so your endstop setup wrong in M574 (Y1 not Y2).
When you jog the Y axis in the positive it should come towards you and away from you when jogging negatively.
You'll also need to adjust your homey and homeall to flip the home direction (and probably change your motor direction too) -
Thank you for the answer.
It was enough to change the M574 Y1.
