    E3D Tool Changer Example Config Files
    426
    • fcwiltundefined
      fcwilt
      This is from the example files which I found in a ZIP named something like this: dc42 Duet2-Wifi Centre=Zero 4xTitan
      Here is the tfree0.g file:
      ; tfree0.g
      ; called when tool 0 is freed
      ;Drop the bed
      G91
      G1 Z4 F1000
      G90
      ;Purge nozzle
      ;M98 P"purge.g"
      ;Move In
      G53 G1 X-160.5 Y50 F50000
      G53 G1 X-160.5 Y100 F50000
      G53 G1 X-160.5 Y120 F50000
      G53 G1 X-160.5 Y142 F5000
      ;Open Coupler
      M98 P"/macros/Coupler - Unlock"
      ;fan off
      M106 P2 S0
      ;Move Out
      G53 G1 X-160.5 Y75 F50000
      Why are there 4 G1 commands under the ;Move In section as opposed to just 2?
      Thanks much.
      jay_s_ukundefined engikeneerundefined fcwiltundefined dc42undefined 4 Replies Last reply Reply Quote 0
        jay_s_uk @fcwilt
        @fcwilt its more to allow someone to set different speeds for the approach, but as you say, in this instance they aren't needed.
        • engikeneerundefined
          engikeneer @fcwilt
          @fcwilt might also allow for easier editing of the approach move as some tools have different depths (e.g. hemera vs v6 bowden)?
          Definitely not needed, but can make it easier to see what's going on and where you can edit things
          i3 clone with a bunch of mods
          • fcwiltundefined
            fcwilt @fcwilt
            @jay_s_uk
            @engikeneer
            All that makes sense.
            It might be good if E3D is going to publish example files to have a few more comments. 😁
            Thanks again.
            • gloomyandyundefined
              gloomyandy
              Remember it is not just the speed of the move it is the path that is taken as well. I think you would need a minimum of 3 moves to keep the same path. You need to be sure that there is no danger of the mounted tool hitting the other docked tools. So for instance moving directly to (-160.5, 120) or even (-160.5, 100) might not be safe to do from some starting points.
                dc42 administrators @fcwilt
                @fcwilt said in E3D Tool Changer Example Config Files:
                Good question! I can see a reason to use three:
                • First move to a position that is clear of the tool but in line with it
                • Then move most of the way in to pick up the tool
                • Do the last part of the move in more slowly
                My current files for 2 Titan bowden and 2 Hemera direct tools use this in tfree0.g:
                G53 G1 X-160.5 Y50 F50000			; move to location
                G53 G1 Y115 F50000				; move in
                G53 G1 Y127.2 F5000
                The Y position of the tool changed when I extended the docks to allow use of the Hemera tools.
                • fcwiltundefined
                  fcwilt @gloomyandy
                  @gloomyandy said in E3D Tool Changer Example Config Files:
                  I have one macro file that does all the putting and getting of tools. I prefer having all the related code together in one file.
                  It accepts parameters from -1 to 3.
                  Passing -1 puts the current tool back in the dock. Passing 0 to 3 gets that tool from the dock.
                  The code performs various error checks and insures the proper paths are taken.
                    gloomyandy @fcwilt
                    @fcwilt So do you have it all working? How many tools and what type?
                    • fcwiltundefined
                      fcwilt @gloomyandy
                      I have the tool putting and getting working. For testing I have just been putting and getting the blank tool plates.
                      I have only one tool and last night decided I wasn't happy with it.
                      So today I am printing the parts for another one that I hope I will like better.
                        gloomyandy @fcwilt
                        @fcwilt One of the things I've found is that fine tuning multiple tools can be tricky. The way the tool sits in the dock can be slightly different for each tool which may mean you need to adjust the pickup/drop off code for each one to get really reliable changes. A combination of several 3d printed parts joined together by bolts all of which have tolerances, needing things like the docking pins to be able to slide, the tension from the filament feed and control wires all add up. Keeps you busy though! Good luck....
                        • fcwiltundefined
                          fcwilt @gloomyandy
                          Thanks.
                          This is the chunk of code which specifies the finally XY position for each tool where docking/undocking will be attempted:
                          ; --- set xpos and ypos variables based on tool variable ---
                          if   var.tool = 0
                            set var.xpos = -156.9 ; determined by testing
                            set var.ypos =  141.5 ; determined by testing
                          elif var.tool = 1
                            set var.xpos =  -67.6 ; determined by testing
                          elif var.tool = 2
                            set var.xpos =   67.0 ; determined by testing
                            set var.ypos =  141.8 ; determined by testing
                          elif var.tool = 3
                            set var.xpos =  157.0 ; determined by testing
