Is this a typo? (Genuine BLTouch installation)
"On Duet 3 it is the io[n].out pin, eg io7.out."
I'm looking for this pin on my 5+, and not seeing it?
Mark
@mac You are looking here, right? https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_connecting#software-setup
io7.out is an example. It's actually a valid pin for Duet 3 mainboard 6HC, not Mini 5+. Earlier in the BLTouch instructions, it says:
For Duet 3 Mini 5+, use IO_1, IO_2 or IO_3.
In step 2 of the configuration, it shows (as an example):
M950 S0 C"io3.out" ; Duet 3 Mini 5+
Relate it to this picture (or the wiring diagram), where
is the number of the io connector you are connecting the probe to:
