    RRF versus Duet3D Mini 5+ documentation
    51
    • Mac
      Mac last edited by Mac
      This post is deleted!
      Mac 1 Reply Last reply Reply Quote 0
      • Mac
        Mac @Mac last edited by
        • droftarts
          droftarts Moderator @Mac last edited by droftarts
          @mac It doesn't apply to Duet 3 Mini 5+. It's a note for people with older Duet 2 boards, that don't have 5V-tolerant probe inputs. For them, the BLTouch output can be changed to 3.3V.
          Edit: All BLTouch need to be powered by 5V. It's flashing because you are powering on 3.3V, which is not what the documentation says.
          • Mac
            Mac @droftarts last edited by Mac
            • Mac
              • droftarts
                @mac Your second video has the BLTouch working correctly; at startup it does 2 self test deploy and retracts, then stays lit up in red. It is supposed to be powered from 5V. That's what the wiring table says to do.
                If you look at the BLTouch documentation, you'll see the BLTouch can OUTPUT 5V, or can be set to OUTPUT 3.3V. On old Duet 2 boards, if you set it to output 5V, the input on the Duet can't cope with that voltage, so you have to set the BLTouch to output 3.3V. It's not relevant any more. It is explained in the Duet 2 section of the documentation. The Duet 3 section has the note that says it doesn't matter.
                As for the motors and the screen, please post your config.g and homex.g files.
                Mac 2 Replies Last reply Reply Quote 0
                • Mac
                  • Mac
                    • Mac
