    Indusctive z probe error
    71
    • Tinchus
      Tinchus last edited by
      Hi. Im having this issue after upgrading to 3.4.1 stable . Duet 3 SBC
      I have a mesh levelling routing, nothing on that start gcode has changed. As aI said the error appears sometimes in version 3.4.1 (previous version used was 3.3)
      Error: Probe was not triggered during probing move
      And also sometimes I get the error:
      Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
      If I let the print continues, the prints Z offset is OK, perfect.
      Any ideas of what can be happening?
      My start gcode is this :
      G21
      M83
      G28
      T0
      G32
      G1 X5 Y5 F2000
      M400
      M141 S90
      G10 S<MAIN1 - 70>
      M116 P0 S5
      G1 X175 Y175 F2000
      G30; Home z again with probe for Z DATUM
      G29; mesh levelling
      G10 S<TEMP>
      M116 P0
      <MATL>
      Thanks in advance
      Tinchus 1 Reply Last reply Reply Quote 0
      • Tinchus
        Tinchus @Tinchus last edited by
        I have more data. The probing error happens when running bed.g
        In that file I do a side by side calibration (both Z motors are independent).
        bed.g:
        G28 ; home
        G1 X182 Y204 F2000
        G30
        G30 P0 X10 Y204 Z-99999 ; probe near left leadscrew
        G30 P1 X345 Y204 Z-99999 S2 ; probe near right leadscrew and calibrate 2 motors
        M400
        With version 3.3 this error was not happening. I have read documentation and I cant find anything related to a change on probing
        Stephen6309 fcwilt 2 Replies Last reply Reply Quote 0
        • Stephen6309
          Stephen6309 @Tinchus last edited by
          @tinchus Make sure you home Z before leveling, that should get rid of the warning about the Z offset.
          Here's my bed.g:
          ; bed.g
          M561						; clear any bed transform
          while iterations < #move.axes & move.axes[iterations].visible
          	if !move.axes[iterations].homed
          		G28
          		break
          G28 Z						; home Z for Z0
          M290 R0 S0					;  clear baby stepping
          G30 P0 X10 Y150 Z-99999		; probe near a leadscrew, half way along Y axis
          G30 P1 X275 Y150 Z-99999 S2	; probe near a leadscrew and calibrate 2 motors
          • fcwilt
            fcwilt @Tinchus last edited by
            @tinchus said in Indusctive z probe error:
            bed.g:
            G28 ; home
            G1 X182 Y204 F2000
            G30
            M400
            A couple of things.
            You should not need that M400.
            And after leveling the bed you should reset the Z=0 Datum with a single G30 at whatever location you normally use.
            • Tinchus
              Tinchus @Stephen6309 last edited by
              @stephen6309 Thank you for this. Can you explain me what these lines are for?
              	G28
              	break
              Also, lets supose the z probe is not triggered an d I get an error, can that error be detected and add some code lines to repeat the probing?
              fcwilt Stephen6309 2 Replies Last reply Reply Quote 0
              • Tinchus
                Tinchus @fcwilt last edited by
                @fcwilt Thank you for the tip, will do it
                • fcwilt
                    G28
                    break
                  That code scans for any un-homed axis and if it finds one it does a "home all".
                  I myself don't use such code because I don't won't homing to occur as a side effect. Probing, other than homing with a probe, should not be happening unless all axes are already homed.
                  But that's just me.
                  • Stephen6309
                    @tinchus To make sure the printer is homed. I also have this in start.g, so it shouldn't run in G32 during a print, but the G28 Z is in there, since the bed is heated up before running G32 and G29/mesh.g for a print. It also allows testing of the G32 without additional steps.
