    Save Z position when shutting down
    Gcode meta commands
    • Lem
      Lem last edited by
      Hi!
      I have a little bit strange construction of Z axis where I have to move up/down extruder for Z homing. Because of this I want to save Z position when printer shutting down and load it after turned on.
      I tried with M911 command but it doesn't work when the printer doesn't have a job. I add macro to executed command in M911 but it works only for shutting down while printing too. Is any other way to do it?
      Greetings!
      infiniteloop 1 Reply Last reply Reply Quote 0
      • infiniteloop
        infiniteloop @Lem last edited by
        @lem said in Save Z position when shutting down:
        Sure. Before shut-down, get to know the position from the object model, then, use echo as described here to write a macro onto the SD card (just a one-liner with G92, followed by X/Y/Z …) which you call when you restart your printer.
        If you need more specific advice after you have studied the links: ask.
        Lem 1 Reply Last reply Reply Quote 0
        • Lem
          Lem @infiniteloop last edited by Lem
          @infiniteloop Thans for reply. But I don't now one thing - which macro / file / command is executed while shutting down? I can't find this in built-in macros (start.g, pause.g, sleep.g, etc.)
          • infiniteloop
            infiniteloop @Lem last edited by infiniteloop
            Usually none. My printer has a separate PSU for the Duet, so that I can shut-off power for steppers and heaters with M81, but I can as well turn the mains switch or pull the plug.
            Either you save the positions in all situations you can think of - end.g, pause, resume, abort, M911 … but you won't catch all possible events. Or you always invoke a macro before you plan to shut the printer off.
            A better way is to use some "auxiliary end switch" for Z so you have a known height before doing the "real" homing - this can be anywhere along the Z axis.
