Console blocked after MAJ 3.4
I'm new in the duet3d world.I have issue with my last software update.
I can't used my duet panel for used the console, when I try to put G-code nothing move. but I can use the web interface and YAT to send G-code.my config:
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.2rc2 (2022-08-10)
Duet WiFi Server Version: 1.26I can give more details if it's need it
If somebody have an solution ?
Thanks -
Do you mean the console tab on the PanelDue?
Does the Paneldue work otherwise?
Have you updated the PanelDue firmware?
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
Do you have
M575 P1 B57600 S1
in your config.g to enable the PanelDue at startup? -
@phaedrux
thanks for your help, the issue for G code "M575 P1 B57600 S1" ( M576 in my code), I close the topic. -
undefined pierre38antoine marked this topic as a question
undefined pierre38antoine has marked this topic as solved
