    how to configure a capacitive sensor
    • axiomundefined
      axiom
      I have a capacitive sensor connected to my board. Unfortunately I don't understand the instructions in the Config tool. What do I have to enter in the tool or in the config?
      Norderundefined 1 Reply Last reply Reply Quote 0
      • Norderundefined
        Norder @axiom
        @axiom
        All of your questions should be answered here.
        It is at least a good starting point to get to the destination.
        DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
        Thingiverse
        axiomundefined 1 Reply Last reply Reply Quote 0
        • axiomundefined
          axiom @Norder
          @norder thank you very much, I had already looked at that and then connected the cables...I have a 3-wire capacitive sensor. My problem is the right call in the code
          • Norderundefined
            Norder @axiom
            @axiom
            Here is an example of what it could look like.
            ; Inductive Z-Probe
            M558 P5 C"!io3.in" H5 F400 T5000 ; set Z probe type to unmodulated and the dive height + speeds
            G31 P500 X-30 Y-15 Z0.20 ; set Z probe trigger value, offset and trigger height
            Please do NOT adopt 1:1, but adapt to your settings.
            What these are is on the previously linked page or on the further links listed there.
            P.S.:
            Could that help you too?
            M558 (GCode Dictionary)
            G31 (GCode Dictionary)
            Google Translate
            --- Original Text ---
            Hier ein Beispiel wie es aussehen könnte.
            ; Inductive Z-Probe
            Bitte NICHT 1:1 übernehmen, sondern Deinen Einstellungen anpassen.
            Welche das sind, steht auf der vorher verlinkten Seite bzw den dort aufgeführten weiterführenden Links.
            Thingiverse
