duet2 found no SD card
Hello friends,
I happened upon an old duet 2 wifi V1.03 that I must have gotten long ago. There is no SD card in it, no clue what firmware is on it. I have no idea where to start. Can anyone help me out?
@phaedrux thanks for that. tried to follow along and couldn't get past connecting to it with yat/pronter face. drivers were loaded, correct com port and baud rate were selected.
Does anything show up in device manager when you connect the Duet?
Do you get the device connected chime when you plug it in?
What LEDs are lit on the Duet?
Try different USB cables and ports.
