    StepTimer.cpp Internals
    Firmware developers
    • ezalys
      ezalys last edited by
      I'm trying to learn a bit about how the step pulse generation works and am starting by digging around in StepTimer.cpp. I'm trying to understand how exactly the timer interrupt works. The first thing I notice is the following comment
      // The clock rate we use is a compromise. Too fast and the 64-bit square roots take a long time to execute. Too slow and we lose resolution.
      Why should the clock rate affect the time of a square root?
      Secondly, I'm not sure how the timers themselves work. Do you try and schedule an interrupt such and such time in the future and put it on a queue, and the ISR looks for the next timer event that should fire and arrange to have the timer interrupt hit you then, or does the ISR itself fire at 1 MHz?
      • ezalys
        After a bit of further investigation, it looks like isqrt64 is never actually called. What then sets the counter frequency?
        JoergS5 dc42 3 Replies Last reply Reply Quote 0
        • JoergS5
          JoergS5 @ezalys last edited by JoergS5
          This post is deleted!
          • JoergS5
              dc42 administrators @ezalys last edited by
              @ezalys the isqrt64 function was used in RRF 3.3 and earlier when the step time computations were done using integer maths. Since RRF 3.4 the maths is done using floating point maths instead. isqrt64 is still used in the Duet3Expansion project, for build configurations that use the SAMC21 processor.
              The step clock rate affected the speed because the square root is much faster to compute when operand fits in 32 bits.
              gnydick 1 Reply Last reply Reply Quote 0
              • gnydick
                gnydick @dc42 last edited by
                @dc42 not really related, but made me think of this, Fast Inverse Square Root. Does those lore make it around your circles?
                  dc42 administrators @gnydick last edited by
                  @gnydick yes I've read about that interesting algorithm before. I know of one place where the reciprocal of a square root is used, so it could perhaps be used there. However, most of the processors we use now support a fast floating point square root instruction.
