CNC Spindle setup "Error: M950: Port must be on main board"
I'm upgrading an LPKF CNC router to a Duet control system. At the moment the main board is a 6XD (although this will change to a 6HC soon) and there is a 1HCL daughter board mounted on the x carriage. The 1HCL I want to use to:
Run the Z axis stepper - working
Input for Z axis end stop - working
Run the spindle - not working
Run the tool change motor - not testedI'm in the process of testing the spindle but get the following m950 error (M115 included since I know that's helpful):
17/11/2022, 12:00:42 M950 R0 C"!123.out0" L62000 Error: M950: Port must be on main board 17/11/2022, 11:59:09 m115 b123 Duet EXP1HCL firmware version 3.4.4 (2022-10-14 11:45:14) 17/11/2022, 11:58:57 m115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6XD FIRMWARE_VERSION: 3.4.4 ELECTRONICS: Duet 3 MB6XD v1.0 or later FIRMWARE_DATE: 2022-10-20 16:19:15 17/11/2022, 11:58:54 Error: M950: Port must be on main board 17/11/2022, 11:58:54 Error: M563: unconfigured spindle 17/11/2022, 11:58:53 Connection established
My config.g
; Configuration file for Duet 3 MB 6XD (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.14 on Wed Nov 16 2022 17:43:38 GMT+0000 (Greenwich Mean Time) ; General preferences G4 S2 ; wait for 2 seconds for expansion boards to start M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name M453 ; set in CNC mode ; Drives M569 P0.0 S1 ; physical drive 0.0 goes backwards M569 P0.1 S0 ; physical drive 0.1 goes backwards M569 P123.0 S0 ; physical drive 0.2 goes backwards M584 X0.0 Y0.1 Z123.0 ; set drive mapping M92 X2133.33 Y2133.33 Z2461.54 ; set steps per mm M566 X900.00 Y900.00 Z480.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z3000.00 ; set maximum speeds (mm/min) M201 X2000.00 Y2000.00 Z20.00 ; set accelerations (mm/s^2) M906 X4000 Y4000 Z2000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X305 Y229 Z25 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io1.in M574 Y1 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io3.in M574 Z1 S1 P"!123.io1.in" ; configure switch-type normally open (e.g. microswitch) endstop for low end on Z via pin 123.io1.in ; Z-Probe M558 P0 H12 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M140 H-1 ; disable heated bed (overrides default heater mapping) ; Fans M950 F0 C"out4" Q ; create fan 0 on pin out4 and set its frequency ; M106 P0 C"Rear Input Fan" SNaN H-1 ; set fan 0 name and value. Thermostatic control is turned off ; Tools M950 R0 C"!123.out0" L62000 ; Set as CNC, Spindle 1 on 1HCL board IO M563 P1 S"Spindle 1" R0 ; Create tool 1 with spindle 0 and call it "Spindle 1" ; Custom settings ;Assumes 1HCL is set to CAN address 123 as default by jumpers rather than 121 as in RepRap config tool ; Set HCL OUT1 as tool change ; Set HCL TEMP0 as carriage temp
In case it helps, the original setup used a DAC1005 with PWM output to the spindle. This post on LinuxCNC might be helpful to understand the original machine setup.
I'm running a Raspberry Pi 3B SBC with separate power supply.Can anyone help with this?
@MaltAndMake looks like spindles aren't supported on CAN boards.
one for @dc42 to change in the firmware -
undefined Phaedrux marked this topic as a question
