    wiring 3rd hotend heater
    • ardisf
      ardisf last edited by ardisf
      can the expansion port on duet 2 wifi be used for the 3rd hotend heater? how is the wiring
      • deckingman
        deckingman @ardisf last edited by
        @ardisf said in wiring 3rd hotend heater:
        Only by adding a Duex 5 expansion board https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview
        ardisf 1 Reply Last reply Reply Quote 0
        • ardisf
          ardisf @deckingman last edited by
          @deckingman is it possible if i use relay direct from power supply and connecting with my 3rd heater?
            dc42 administrators @ardisf last edited by
            Yes if your relay or mosfet switch has an opto isolated input and will switch with just 3.3V across the input. Connect the + side of the input to +3.3V and the - side of the input to E2_HEAT on the expansion bus.
            • ardisf
              ardisf @dc42 last edited by
              @dc42 where is exactly pin E2_HEAT on the expansion bus?
                Phaedrux Moderator @ardisf last edited by
                @ardisf It is heater3 on the expansion bus.
                https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pin-names
