Solved Paneldue 7i
Is there a way to set the Paneldue 7i so that the text is not outside the display?
@Proschi78 Never seen that problem...
Are you sure that it is not the housing which covers the display? -
@cosmowave it actually looks like this in the picture.
Yes, the cover of the housing overlaps 2-3 mm.
but the text is still outside of the display.
I just updated the firmware yesterday.
since then I have the problem -
@Proschi78 the text in the macro buttons will be truncated to fit, but I think the other text should fit if you adjust your enclosure so as not to cover the right edge of the screen.
@dc42 I'll take a picture again this afternoon when it's dismantled.
top right says idle (Leerlauf in German), this is also truncated.
with the macros, I thought it was too long for the text. -
@Proschi78 said in Paneldue 7i:
Yes I can see that; however it's clear that the right hand edge of all 6 buttons on the right hand side missing, so if the enclosure is obscuring those then it is probably obscuring the 'f' too.
@dc42 topic done. It was really deceptive because so much is missing from the macros
