    Vertical Load of the Stepper motors
    • jaydevdaveundefined
      jaydevdave
      I want to know what is the maximum vertical load in kilograms can be supported by the duet wifi. I am using Nema 17 stepper motors with holding torque 0.55Nm or 5.5kg.cm
      Thank you!
      • DocTruckerundefined
        DocTrucker
        People will need more information.
        Assume you mean z-axis?
        Belt drive or screw drive?
        Pulley diameter or screw pitch?
        What current limit have you set?
