Solved Duet2 wifi + ebmpapst fan wiring
Printer: Ender 5 Pro,
Mainboard: Duet2 Wifi
Extruder/Hotend: E3D 24VDC Hemera Revo
Part Cooling Fan: 24VDC ebmpapst 5015, model RLF35-8/12N
Bed Sensor: BL TouchI have an ender5 Pro that I am updating to use this new fan duct design for the Hemera Revo + 5015 epmpapst blower.
https://rene-jurack.de/well-engineered-hemera-fan-duct-2/The part cooling fan that I am removing only had two leads (PWR & GND). The new fan has three leads, one for PWR (red), GND (black), and PWM (blue).
I found the following post that describes how to connect it to the Duet2:
https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Connecting_3_or_4_wire_fansMy current fan connections are:
PWM Fans V_FAN connected to Red PWR
PWM Fans FAN0(-) connected to Black GNDOn Duet 2, for 3-wire fans, the recommended connections are:
Red (PWR) of an always-on fan connector.
Black (GND)
Blue (PWM control) connect it to the FAN- pin of your chosen controlled fan connector.Question:
Before I start changing connections I wanted to ask about the GND. I am attempting to connect this new fan without fishing another wire up through the to the hotend. I am only missing the GND for the new fan connection. The only GND wire I have going to the Hemera that I could splice from looks like the GND going to the BL Touch.I know that for a two wire PWM fan the GND is the PWM control and you cannot bond that GND with other GND wires. However, for the three wire fans I believe it will be OK to bond the GND of the part fan with the GND on the BL Touch since it is truly acting as a standard GND. I wanted to get the forum's experienced opinion on the matter. Is it OK to bond the BL Touch GND with my three wire ebmpapst GND?
My new connections would be:
Always On Fans V_FAN connected to Red PWR of 5015
Splice the GND going to BL Touch and connect to GND (Black) of 5015
PWM Fans FAN0(-) connected to Blue (PWM Control) of 5015 -
@mitch said in Duet2 wifi + ebmpapst fan wiring:
RLF35-8/12N
that fan will use about 0.3A when on max so its likely that the ground wire of the BL touch will be suitable to carry that return current (although i would check).
The issue you may find is that electrical noise from the fan disturbs the operation of the BLtouch. that may not be an issue if you never probe with the fan running any way.
@T3P3Tony Thanks. I had a more accessable ground going to my filament runout sensor so I ended up using that.
