    Solved M672 set sensitivity smart effector not working
    • ladal
      ladal last edited by
      I have two versions of smart effector "v2 and v4", I have the same problem with both.
      To set the sensitivity, only the example "M672 S105:50:205" works and returns the setting "M672 S105:205:50".
      The sensitivity changes and the LED flashes 5 times.
      If I try to change it to a value other than "50" or "205", no change is made, nor does the LED blink. Diagnostic and reset commands work correctly.
      Thanks in advance for your answer
      Lada
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @ladal last edited by
        @ladal both values have to equal 255, you can't change one value and not the other.
        See here https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m672-program-z-probe
        ladal 1 Reply Last reply Reply Quote 0
        • ladal
          ladal @jay_s_uk last edited by
          @jay_s_uk
          Thanks much, I am very stupid 🙂
          Lada
          • Topic has been marked as a question  Phaedrux Phaedrux
          • Topic has been marked as solved  Phaedrux Phaedrux
