    Duet time estimation….
    • peirof
      peirof last edited by
      In Duet Web Control–>Print Status. There is a section, of time estimation, with 3 diferent times
      Based on Filament Usage
      File Progress
      Layer Time
      What correspond those times?
      How they are calculated?
      The only time i understand is the Time estimation in base of filament usage, think is the time, aprox., the print will finish.
      But the other 2 times, i understand.
      Thanks
      • deckingman
        deckingman last edited by
        AFAIK they are all based on what has happened so far, then extrapolated to the end of the print based on the same rate of change for each parameter.
          If you want a more accurate estimate, run the print in simulation mode.
          • fma
            fma last edited by
            It would be interesting to plot the evolution of these 3 computed end times during the print, to see how they evolve. I guess it depends on the part printed, but there is maybe something to find out from this…
            Frédéric
            • deckingman
              Yes it depends entirely on the part being printed. For example, if the first few layers are a lot bigger than the rest, then the calculated time to finish the print based on layer time will be a long way out at the beginning but get closer towards the end, as the average layer time diminishes. If the layers are all about the same size with the same amount of infill, then the calculated time based on layer time will be a lot closer. If the object was like an inverted cone, with layers getting bigger, then the calculated time to completion will be low at the start. Similar scenarios apply to filament usage and file size. The calculations don't lookahead so can only be based on what has happened so far and not what must happen in the future. As David said, the only way to get an accurate estimate is run the print in simulation mode.
              • peirof
                Ok… Thanks... But, in gcode there is the meters of filament used in the file printed, and the speed that have the printer during work...
                Why can't know the Duet estimated time?
                • SuperJETT
                  SuperJETT last edited by
                  Because infill, perimeters, etc etc can all run at different speeds. In my experience that's the closest, but my first layer is always solid and .2mm where the rest of the print may be .1mm or .35 which means the time has to be recalculated and averaged out to be close.
                  Custom CoreXY at home with Duet Wifi, Hemera
