    PanelDue not displaying Temperatures
    PanelDue
    • rodneysramosjundefined
      rodneysramosj
      We are trying to troubleshoot a custom 3D printer however the temperatures will not display on the PanelDue 7i. We are using 3.5.1 for Printer and Panel Firmware. using duetweb control and reprap config tool. everything seems to be working normally but we just cant get the panel to display properly.
      ; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC
      ; generated by RepRapFirmware Configuration Tool v3.5.10 on Wed Feb 26 2025 14:22:18 GMT-0500 (Eastern Standard Time)
      ; General
      G90 ; absolute coordinates
      M83 ; relative extruder moves
      M550 P"Duet 3" ; set hostname
      ; Accessories
      M575 P1 S1 B115200 ; configure PanelDue support
      M551 P"Password1" ; set machine password
      M552 P192.168.1.20 S1 ; configure Ethernet adapter
      M553 P255.255.255.0 ; set netmask
      M554 P192.168.1.254 ; set gateway
      M586 P0 S1 ; configure HTTP
      ; Wait a moment for the CAN expansion boards to become available
      G4 S2
      ; Smart Drivers
      M569 P0.0 S1 D2 ; driver 0.0 goes forwards (X axis)
      M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Y axis)
      M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Z axis)
      M569 P0.3 S1 D2 ; driver 0.3 goes forwards (extruder 0)
      ; Motor Idle Current Reduction
      M906 I30 ; set motor current idle factor
      M84 S30 ; set motor current idle timeout
      ; Axes
      M584 X0.0 Y0.1 Z0.2 ; set axis mapping
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M906 X2800 Y2800 Z6000 ; set axis driver currents
      M92 X53.33 Y53.33 Z400 ; configure steps per mm
      M208 X0:1060 Y0:530 Z0:1000 ; set minimum and maximum axis limits
      M566 X3000 Y3000 Z60 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
      M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
      ; Extruders
      M584 E0.3 ; set extruder mapping
      M350 E16 I1 ; configure microstepping with interpolation
      M906 E450 ; set extruder driver currents
      M92 E2682 ; configure steps per mm
      M566 E120 ; set maximum instantaneous speed changes (mm/min)
      M203 E3600 ; set maximum speeds (mm/min)
      M201 E250 ; set accelerations (mm/s^2)
      ; Probes
      M558 K0 P1 C"io5.in" H2.5 F120 T6000 ; configure analog probe via slot #0
      G31 P500 X0 Y0 Z3.5                  ; set Z probe trigger value, offset and trigger height
      ; Kinematics
      M669 K0 ; configure Cartesian kinematics
      M574 X1 P"io3.in" S1 ; configure X axis endstop
      M574 Y1 P"io1.in" S1 ; configure Y axis endstop
      M574 Z1 P"io2.in" S1 ; configure Z axis endstop
      ; Sensors
      M308 S0 P"temp0" Y"thermistor" A"Heated Bed Set 0" T200000 B3950 C6.370029e-8 ; configure sensor #0
      M308 S1 P"temp1" Y"thermistor" A"Heated Bed Set 1" T200000 B3950 C6.370029e-8 ; configure sensor #1
      M308 S2 P"temp2" Y"thermistor" A"Roto Internal Temp" T100000 B4267 C7.046861e-8 ; configure sensor #2
      M308 S3 P"121.temp0" Y"thermistor" A"Roto Extruder Temp" T100000 B4267 C7.046861e-8 ; configure sensor #3
      M950 H0 C"out1" T0 ; create heater #0
      M143 H0 P0 T0 C0 S120 A0 ; configure heater monitor #0 for heater #0
      M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0
      M950 H1 C"121.out0" T3 ; create heater #1
      M143 H1 P0 T3 C0 S300 A0 ; configure heater monitor #0 for heater #1
      M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
      M950 H2 C"out2" T1 ; create heater #2
      M143 H2 P0 T1 C0 S120 A0 ; configure heater monitor #0 for heater #2
      M307 H2 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #2
      ; Heated beds
      M140 P0 H0 ; configure heated bed #0
      M140 P2 H2 ; configure heated bed #2
      M950 F0 C"out0+out5.tach"         ; create fan #0
      M106 P0 C"Roto Fan" S0 B10 H2 T45 ; configure fan #0
      M563 P0 S"Roto Toolboard" D0 H1 F0 ; create tool #0
      M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
      T0 ; select first tool
      ; Custom settings
      ;E-Stop
      M950 J4 C"!^io4.in"
      M581 P4 S0 T0 R0
      * list item
        Are they displaying correct on the web control?
        What exactly are you seeing on the PanelDue? Photo?
        Can you describe the heater layout for the printer?
