    G32 causes printhead to go beyond limits
    • justGunerundefined
      justGuner
      I am trying to get G32 working for my printer in order to compensate for what i suspect is a slightly twisted x axis (my bed meshes always come at an angle despite manual leveling). I followed the instructions from https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling . However, upon sending G32, the printhead probes at about 50mm near the first leadscrew, and then it crashes into the axis limit trying to reach the second leadscrew.
      Here are the config and bed files:
      ; Configuration file for BTT SKR 3 EZ (firmware version 3)
      G4 S2                                          ; wait 2 seconds
      M669 K1                                        ; select CoreXY mode
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"My Printer"                             ; set printer name
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      ;M586 P2 S0                                     ; disable Telnet
      M569 P0 S1 D2                                    ; physical drive 0 goes forwards using default driver timings
      M569 P1 S1 D2                                    ; physical drive 1 goes forwards using default driver timings
      M569 P2 S0 D2                                  ; physical drive 2 goes forwards using default driver timings
      M569 P3 S0 D2                                   ; physical drive 3 goes forwards using default driver timings
      M569 P124.0 S1				       ; physical drive 124.4 goes forwards using default driver timings
      M584 X0 Y1 Z2:3 E124.0                              ; set drive mapping
      M350 E256 I0                              ; configure microstepping with interpolation
      M350 X16 Y16 Z32 I1                                ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E6501         ; set steps per mm
      M566 X900.00 Y900.00 Z200.00 E1200.00           ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z1000.00 E3000.00        ; set maximum speeds (mm/min)
      M201 X15000.00 Y15000.00 Z500.00 E5000.00         ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z800 E800 I5                  ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                       ; Set idle timeout
      ;M556 S1 X-0.0036843
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X265 Y280 Z290 S0                         ; set axis maxima
      M574 X2 S1 P"e0stop"                            ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
      M574 Y2 S1 P"e1stop"                            ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M950 S0 C"124.io0.out"                              ; create servo pin 0 for BLTouch
      M558 P9 H5 F250:60 T8000 C"124.io0.in"                ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-22.345 Y-6.941 Z0.689                            ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:215 S50                       ; define mesh grid
      M671 X-22:287 Y163:163
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bed" T0                              ; create bed heater output on bed and map it to sensor 0
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M307 H0 R0.320 K0.414:0.000 D1.01 E1.35 S1.00 B0 V24.6 ; set PID values for heated bed
      M143 H0 S130                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"124.temp0" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"124.out0" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300                                   ; set temperature limit for heater 1 to 300C
      M307 H1 R3.201 K0.662:0.000 D9.07 E1.35 S1.00 B0 V24.0 ; set PID values for heater 1
      M950 F0 C"124.out2" Q250                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                           	   ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"124.out1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S0 H1 T100                                 ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                               ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      T0                                             ; select first tool
      ; TFT Screen
      ;M575 P1 S0 B115200				; enable support for tft
      M955 P124.0 I10
      M572 D0 S0.035
      M912 P0 S-8.9
      M593 P"zvdd" F41 ; use ZVDD input shaping to cancel ringing at 41Hz
      M308 S2 Y"drivers" A"DRIVERS"  			; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S3 Y"mcu-temp" A"MCU" 			; configure sensor 3 as on-chip MCU temperature sensor
      M308 S4 Y"thermistor" P"124.temp1" A"RRF_36" T100000 B4092	; configure sensor 4 as temperature sensor on RRF36 CAN-FD board
      M950 F2 C"fan2" Q20000 				; create fan 2 on pin fan2 and set its frequency
      M106 P2 H2:3 L0.15 X0.65 B0.3 T40 		; set fan 2 value
      M501
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.4.0-LPC-STM32+7 on Sun Aug 20 2023 12:46:47 GMT+0300 (Eastern European Summer Time)
      G28 ; home
      while true
          G30 P0 X0 Y140 Z-99999 ; probe near a leadscrew, half way along Y axis
          G30 P1 X265 Y140 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
          if abs(move.calibration.initial.deviation) < 0.01 || iterations > 3
              break
        droftarts administrators @justGuner
        @justGuner G32 calls bed.g, which in turn usually runs a number of G30 commands. From https://docs.duet3d.com/en/User_manual/Reference/Gcodes#g30-single-z-probe
        Caution: the XY coordinates are permitted to be outside the normal printable bed area! This is intentional, because some printers (e.g. delta printers) benefit from probing areas not used for printing.
        It is up to the user to check that the G30 commands are reachable. It looks like the your's trying to probe at the X limit (X265 in the second G30 command in bed.g), but with the probe offset in config.g (G31 P500 X-22.345 Y-6.941 Z0.689) it may cause a crash. I suggest changing the X265 to X240.
        justGunerundefined 1 Reply Last reply Reply Quote 0
          justGuner @droftarts
          @droftarts I am also trying to probe at the min. edge of the x axis, however the printhead stops about 20-30mm from the edge. Am I supposed to subtract the offset from both probing coordinates?
          When I specify x and y, are those the coordinates for the printhead or bltouch?
            @justGuner said in G32 causes printhead to go beyond limits:
            When you specify X and Y in G30, the coordinates are of the probe, not the printhead (assuming the printhead is the HRP, ie where XYZ = 0), so it takes the offsets in G31 into account. If you want to probe to the edge of the bed, and the probe is offset from the printhead, the printhead will go off the edge of the bed. Make sure there is clearance to do this.
            Your G31 command (G31 P500 X-22.345 Y-6.941 Z0.689) implies the probe is to the left and in front of the nozzle. Is that correct? Because it sounds like it's on the right of the nozzle. If not, see https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing#measuring-probe-x-y-offset
              @droftarts Yes, the probe is to the left and in front of the nozzle
                justGuner @justGuner
                I have edited the coordinates for probing and now it behaves as it should. However, I keep on getting the following error:
                Error: Some computed corrections exceed configured limit of 1.00mm: 2.404 -2.621
                Can I increase the configured limit?
                edit: nevermind, I figured it out (it's the S parameter in M671). Probing works as it should now.
                  That's coming from your M671 command in config.g, which defines the leadscrew positions:
                  See https://docs.duet3d.com/User_manual/Reference/Gcodes#m671-define-positions-of-z-pivot-points-or-bed-levelling-screws
                  You have omitted the S parameter, so it is defaulting to 1mm. If the levelling is likely to move, it's worth making the first probe have a wider limit eg M671 ... S5, with more probe lift (M558 H parameter).
