    Bl touch problem and slow homing speed after upgrade to 3.5.4
    129
    • kilopundefined
      kilop
      Hi all
      After years of using 2.0.2 firmware I decided to upgrade my HEVO to newest 3.5.4 firmware and I fallowed documentation so fist update to 3.0 then to 3.2.2 and then to 3.5.4 the only change I done was a change of pin for bl-touch pwm signal from heater 7 ( on 2.0.2) to heater 3 (pin 8 on duet wifi 1.02) but this was made after i observed problems with bltouch just to check.
      Now i think I converted my config correctly for 3.5.4 fw but I observed that travels speed is super low ( when moving axies via DWC ) and the most important when BLtouch touches first time bed when trying to home Z it release pin after it goes up and meantime bed is still moving up and not stoping after first touch and not reverse movement ( down ) after that touch . it looks like it is not making any pause on bl touch behavior after first touch and also Z axis continuing moving in the direction of the homing 😞
      I really need some help from you guys as I didin't use that printer for some time and now it's needed to print soem bigger parts and I just can not do it 😞
      I was even thinking of erase duet somehow and just put 3.5.4 is there way of doing that as well , maybe something went wrong during updates ?
      should I move bl-touch to heater 7 pin in duet like i had it befoure ?
      My old config for 2.0.2 firmware :
      ; generated by RepRapFirmware Configuration Tool on Sun Sep 09 2018 19:41:51 GMT+0100
      G90                                                ;* Send absolute coordinates...
      M83                                                ;* ...but relative extruder moves
      M667 S1                                            ; Select CoreXY mode   M669 K1 for 3.5.4
      M550 Pduetwifi                                     ; Set machine name
      M551 xxxx                                         ; Set password
      M552 S1                                            ; Enable network
      M587 S"xxxx" P"xxxx"	       ; WiFi Home
      M586 P0 S1                                         ;* Enable HTTP
      M586 P1 S1                                         ;* Enable FTP
      M586 P2 S1                                         ;* Enable Telnet
      M569 P0 S0                                         ;* Drive 0 goes backwards X
      M569 P1 S0                                         ;* Drive 1 goes backwards Y
      M569 P2 S0                                         ;* Drive 2 goes backwards Z
      M569 P3 S1                                         ;* Drive 3 goes forwards E0
      M350 X16 Y16 Z16 E16 I1                            ;* Configure microstepping with interpolation
      M92 X80 Y80 Z1600 E406.79                          ;* Set steps per mm
      ;;M566 X600 Y600 Z12 E120
      M566 X600 Y600 Z12 E300							   ;* Set maximum instantaneous speed changes (mm/min)
      ; M203 X6000 Y6000 Z300 E1200
      M203 X8000 Y8000 Z100 E9000                        ;* Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z50 E500                          ;* Set accelerations (mm/s^2)
      ;;M201 X2000 Y2000 Z50 E5000
      M906 X900 Y900 Z1100 E800 I30                      ;* Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ;* Set idle timeout
      M208 X0 Y0 Z0 S1                                   ;* Set axis minima
      M208 X296 Y300 Z326.5 S0                           ;* Set axis maxima
      M574 X1 Y1 S1                                      ;* Set active high endstops
      M574 Z1 S2 					   					   ;;* Define Z to use Probe. Home to Min
      ; Filament sensor
      M591 D0 P1 C3 S1				   				   ;* Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0)
      M307 H7 A-1 C-1 D-1				   					;; Disable heater on PWM channel for BLTouch
      ;;M558 P0 H5 F120 T6000                             ;* Disable Z probe but set dive height, probe speed and travel speed  F120
      ;;M558 P9 X0 Y0 Z1 H5 F120 T6000 	           		;* Set Z Probe to type Switch or Digital output where Z probe connector is used. Used for z only.;
      M558 P9 H5 F200 T6000                              	;* Set Z probe type to bltouch and the dive height + speeds Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
      ;;G31 P50 X24 Y2 Z1.503				   				;* Set Z probe trigger value, offset and trigger height  zmienic o 0.15~0.20
      ;;G31 P50 X24 Y2 Z1.253
      G31 P50 X24 Y2 Z1.303
      M557 X25:285 Y25:285 S86.66                        ;* Define mesh grid
      ; Heaters  ***
      M307 H0 B0 S1.00                                   ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4138 R4700                        ; Set thermistor + ADC parameters for heater 0
      ;M305 P0 T100000 B4725 R7.06e-8 1                  ; Set thermistor + ADC parameters for heater 0 ATC Semitec 104GT-2/104NT-4-R025H42G triangelabs
      M143 H0 S120                                       ; Set temperature limit for heater 0 to 120C
      ;M305 P1 T100000 B3950 C3.000000e+1 R4700          ; Set thermistor + ADC parameters for heater 1
      ;;M305 P1 T100000 B3950 R4700 H30 L0 		   ; dla tego nowego w metalu
      M305 P1 T100000 B4138 R4700                        ; Set thermistor + ADC parameters for heater 1
      ;M305 P1 T100000 B4138 C0 R4700		           ; Set thermistor + ADC parameters for heater 1
      M307 H1 A673.7 C154.3 D6.4 S1			   ;; Wyniki zPID tuning do 210C  M303 H1 P1 S210 --> M307 Heater 1 model: gain 673.7, time constant 154.3, dead time 6.4, max PWM 1.00, calibration voltage 25.0, mode PID, inverted no, frequency default
      M307 H1 A789.8 C177.5 D6.3 S1  			   ;; PID tuning do 220C
      M143 H1 S293                                       ; Set temperature limit for heater 1 to 293C
      ;M106 P0 S0.1 I0 F500 H-1                          ;* Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P0 S0 I0 F500 H-1
      M106 P1 S1 I0 F500 H1 T45                          ;* Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 I0 F500 H-1                             ;* Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1                                      ; Define tool 0
      G10 P0 X0 Y0 Z0                                    ; Set tool 0 axis offsets
      G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
      ; Automatic power saving
      M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ;;M501						   ; Load Mesh bed leveling and other PID settings at startup
      ; Miscellaneous.
      T0                                                 ; Select first tool
      ;;M21 P1					   ; SDcard Panel Due mount
      G29 S1						   ; Enable automatic bed mesh compensation
      ;M572 D0 S0.05                                     ; Enable pressure-advance   dobre Ziro 3d White  1.05-1.15   1.4-1.5
      ;;M572 D0 S1.08                                    ; Enable pressure-advance
      ;; stare do ziro pla
      ;;M207 S4.50 R-0.10 F4800 T3500 Z0.1		   ; set retraction length / speed
      M207 S5.8 R-0.08 F4800 T3500 Z0.1		   ; set retraction length / speed
      and I tried to copy all settings to new config for 3.5.4 fw :
      ; Configuration file for RepRapFirmware on Duet 2 WiFi
      ; generated by RepRapFirmware Configuration Tool v3.5.10 on Sat Apr 26 2025 22:19:20 GMT+0100
      ; General
      G90        ; absolute coordinates
      G21        ; Work in millimeters
      M83        ; relative extruder moves
      M550 P"Duet2WiFi"                                                   ; set hostname
      M911 S19.8 R26 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                ; set voltage thresholds and actions to run on power loss
      ;M911 S22 R26 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                  ; Set voltage thresholds and actions to run on power loss
      ; Power monitoring and loss actions
      ;;M911 S22 R26 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ;;M911 S21 R26 P"M913 X0 Y0 M84 G91 M83 G1 Z5 E-5 F1000" ; Adjusted voltage thresholds and actions
      ; Accessories
      M575 P1 S0 B57600                                                   ; configure PanelDue support
      ;;M551 P"1111"                                                        ; set machine password
      M552 S0 															; disable WiFi adapter
      G4 P500 															; wait half a second
      M552 S1 															; enable WiFi adapter
      G4 P500 															; wait a half second
      ;;M587 S"xxx" P"xxxxx" 				; configure WiFi Home using DHCP
      M586 P0 S1                                                          ; configure HTTP
      M586 P2 S1                                                          ; configure Telnet
      M586 P1 S1                                                          ; configure FTP
      ; Smart Drivers
      M569 P0 S0 D2                                                       ; driver 0 goes backwards (X axis)
      M569 P1 S0 D2                                                       ; driver 1 goes backwards (Y axis)
      M569 P2 S0 D2                                                       ; driver 2 goes backwards (Z axis)
      M569 P3 S1 D2                                                       ; driver 3 goes forwards (extruder 0)
      ; Motor Idle Current Reduction
      M906 I30                                                            ; set motor current idle factor
      M84 S30                                                             ; set motor current idle timeout
      ; Stall Detection
      M915 X Y S5 F0 H200 R0                                              ; X / Y  Axes
      ; Axes
      M584 X0 Y1 Z2                                                       ; set axis mapping
      M350 X16 Y16 Z16 I1                                                 ; configure microstepping with interpolation
      M906 X900 Y900 Z1100                                                ; set axis driver currents
      M92 X80 Y80 Z400                                                    ; configure steps per mm
      M208 X0:296 Y0:300 Z0:326.5 S0                                            ; set minimum and maximum axis limits
      M566 X900 Y900 Z12                                                  ; set maximum instantaneous speed changes (mm/min)
      M203 X8000 Y8000 Z120                                               ; set maximum speeds (mm/min)
      M201 X1000 Y1000 Z50                                                  ; set accelerations (mm/s^2)
      ; Extruders
      M584 E3                                                             ; set extruder mapping
      M350 E16 I1                                                         ; configure microstepping with interpolation
      M906 E900                                                           ; set extruder driver currents
      M92 E406.79                                                         ; configure steps per mm
      M566 E300                                                           ; set maximum instantaneous speed changes (mm/min)
      M203 E9000                                                          ; set maximum speeds (mm/min)
      M201 E500                                                           ; set accelerations (mm/s^2)
      ; Kinematics
      M669 K1                                                             ; configure CoreXY kinematics
      ; Probes
      M558 K0 P9 C"!^zprobe.in" H5 F500 T6000                              ; configure BLTouch probe via slot #0
      ;;M558 K0 P9 C"!^zprobe.in" H5 F200 T6000                              ; configure BLTouch probe via slot #0
      ; Probe offsets and trigger height
      G31 P50 X24 Y2 Z1.303                                                ; Set Z probe trigger value, offset and trigger height
      ;;M950 S0 C"zprobe.mod"
      M950 S0 C"exp.heater3"                                               ; create servo #0 for BLtouch on Duet 2 WiFi/Ethernet
      ;;M558 S0 P50                                                        ; set servo frequency for BLTouch (50 Hz)
      ; Mesh Bed Leveling Grid
      M557 X25:285 Y25:285 S86.66                                         ; Define mesh grid
      M574 X1 P"xstop" S1                                                 ; configure X axis endstop
      M574 Y1 P"ystop" S1                                                 ; configure X axis endstop
      M574 Z1 S2                                                          ; Define Z to use Probe. Home to Min
      ; ; Sensors - Configure thermistors using M308
      M308 S0 P"bedtemp" Y"thermistor" A"Heated Bed" T100000 B4138 C0      ; configure sensor #0 (Heated Bed)
      M308 S1 P"e0temp" Y"thermistor" A"Nozzle" T100000 B4138 C0          ; configure sensor #1 (Nozzle)
      ; Filament sensor
      ;;M591 D0 P1 C3 S1				                                    ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0)
      M591 D0 P1 C"e0stop" S1                                             ;  to  check if it works
      M950 H0 C"bedheat" T0                                               ; create heater #0 Bed
      M143 H0 P0 T1 C0 S120 A0                                            ; configure heater monitor #0 for heater #0
      ;;M307 H0 R2.43 D5.5 E1.35 K0.56 B0                                 ; configure model of heater #0
      M307 H0 R0.728 K0.448:0.000 D1.53 E1.35 S1.00 B0                    ; Auto tuning heater 0 completed after 7 idle and 7 tuning cycles in 1032 seconds. This heater needs the following M307 command:
      M950 H1 C"e0heat" T1                                                ; create heater #1 Extruder nozzle head
      M143 H1 P0 T1 C0 S293 A0                                            ; configure heater monitor #0 for heater #1
      M307 H1 R2.43 D5.5 E1.35 K0.56 B0                                   ; configure model of heater #1
      ; Heated beds
      M140 P0 H0                                                          ; configure heated bed #0
      M950 F0 C"fan0"                                                     ; create fan #0
      M106 P0 S0 L0 X1 B0.1                                               ; configure fan #0
      M950 F1 C"fan1"                                                     ; create fan #1
      M106 P1 S0 B0.1 H1 T45                                              ; configure fan #1
      M950 F2 C"fan2"                                                     ; create fan #2
      M106 P2 C"LED" S0 L0 X1 B0.1                                        ; configure fan #2
      M563 P0 D0 H1 F0                                             ; Define tool 0 with extruder 0 and heater 1
      M568 P0 R0 S0                                                       ; set initial tool #0 active and standby temperatures to 0C0
        droftarts administrators @kilop
        @kilop It looks like you have the wrong steps per mm for the Z axis, which will make it move much slower, and 1/4 of the actual distance you want:
        Old
        New
        M92 X80 Y80 Z400
        Change Z to Z1600.
        The BLTouch input pin is configured incorrectly. You have:
        It should be without the !
        M558 K0 P9 C"^zprobe.in" H5 F120 T6000
        See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_BLTouch#configuration
        F500 is also pretty fast, but you may have changed this to speed up the Z axis. You can set two F parameters, one fast, one slow eg F500:F100, and it will do two probes, one fast and another slow. See the other M558 parameters here: https://docs.duet3d.com/User_manual/Reference/Gcodes#m558-set-z-probe-type
        Otherwise, I can't see anything else amiss.
        Check that:
        • the BLTouch runs the self test at startup, deploying and retracting twice. This means it is getting power, and is grounded.
        • the BLTouch deploys when you send M401, and retracts when you send M402. This means the servo pin (exp.heater3) is working correctly
        • you can see the Z-Probe is reporting correctly in DWC (ie should be 0 most of the time, and briefly go to 1000 when triggered). This checks the BLTouch connection to probe.in.
        If that doesn't help see https://docs.duet3d.com/User_manual/Troubleshooting/BLTouch_troubleshooting
        Post your homeall.g, deployprobe#.g and retractprobe#.g and a picture of your BLTouch wiring (both ends) if you still have problems.
        • kilopundefined
          kilop
          @droftarts said in Bl touch problem and slow homing speed after upgrade to 3.5.4:
          Hi Ian
          steps for Z axis are correct as this is very dense thread and it is ok
          about that
          when I firstly set this option like that Z ( table in my hevo was going down so i reversed that with ! so then table is moving to BL touch probe.
          F500 was set for tests and there is no difference between 120 and 500 thats the problem besides I can see how super slow are other moves like homing or normal travel of the axies .
          BL touch is perfectly fine it was working befoure FW upgrade so no hardware malfunction here .
          day befoure FW upgrade I was using printer and as you can see in my 2.0.2 config same steps now a bit more Amperage on the motors thats it .
          401 and 402 are working fine
          deploy probe :
          M280 P0 S10 I1
          rectract probe:
          M280 P0 S90 I1
          all checked and it gives same behavior like 401 and 402 also all scripts for bltouch works fine so i can reset alarm etc etc .
          and yes bl touch making self test at the printer start.
          here is test of new homez.g
          G91               ; relative positioning
          M564 S0 H0        ; ewentualnie to mozna uzyc zamiast
          G1 Z10 F6000 S2   ; lift Z relative to current position
          G1 H2 Z15 F600 ; lift Z by 15 mm at 600 mm/min
          G90
          ; ZMIANA: Zaktualizowano komentarz dla BLTouch
          ;;M98 Pdeployprobe.g      ; deploy BLTouch
          ;;M401                        ; deploy BLTouch
          ; ZMIANA: Zastąpiono homing z endstopem procedurą BLTouch
          ;G1 S1 Z-255 F2500 ; move Z down until the endstop is triggered
          ;;;;G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
          G90               ; absolute positioning
          G1 X0 Y10 F6000   ; go to first bed probe point and home Z
          M401
          G30               ; home Z by probing the bed
          G1 S2 Z10 F500   ; lift Z relative to current position
          ;;M98 Pretractprobe.g     ; retract BLTouch
          M402                    ; retract BLTouch
          as there is no need to try home all if homez because of that strange bl touch behavior is not solved.
          I will be away for a week or so so .
          fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @kilop
            @kilop said in Bl touch problem and slow homing speed after upgrade to 3.5.4:
            What do you mean by "very dense"?
            Did you change the lead screw(s) when you upgraded the firmware?
            kilopundefined 1 Reply Last reply Reply Quote 0
            • kilopundefined
              kilop @fcwilt
              @fcwilt
              its not a regular 8mm printer
              STEPS are correct for this axis end of discussion about steps for Z axis please
              there wasnt any hardware change just firmware upgrade ( post 1)
              again the problems are:
              1: super slow movements homing and normal movements on all axies x y Z
              2: Z axis continues movement forward bltouch after first touch and it should stop and reverse a bit
              3: almost instant deploy of probe pin after first touch of bltouch to the bed surface
              so this is nothing with mechanical issue ...
              • fcwiltundefined
                fcwilt @kilop
                But you changed the setting when you upgraded the firmware.
                That suggests a change in the hardware.
                • kilopundefined
                  kilop @fcwilt
                  @fcwilt
                  OMG I posted wrong file at the beggining my fault sorry Z has 1600 steps on the machine
                  it's my fault when I was posting i used winmerge and probably copied from wrong window
                  but like i wrote in my last message Z axis is not stoping after first contact of bltouch with the table and pin drops meantime Z is traveling forward nozzle and bltouch I will try to make a video today and upload it somewhere to show you
                    This isn't how you change the direction of homing. All the ! does is invert the probe reading. I expect the Z moves the other way as it sees the Z probe as triggered. What does the Z-probe reading report in DWC? It should be 0 when not triggered. On BLTouch it will very briefly go to 1000 (usually too fast to be reported by DWC).
                    See https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing
                    As for the Z speed, that's limited by
                    It's possible the M558 F parameter overrode this limit in older firmware versions, it doesn't now.
