    Error - Incompatible software version
    153
    • 3DPMicroundefined
      3DPMicro
      6HC, Pi5 new installation. Current FW 3.5.3. At boot I get this message in DWC that reads "the installed software versions do not match. Please operate your setup only at equal versions to avoid potential incompatibilities and unexpected errors."
      Everything appears to be functioning correctly except sending M997 S2 fails to update to 3.5.4. The update initiates but after several minutes the screen goes dark and the Pi is cool to the touch with red indicator light. All leds on Duet are normal. A reboot results in same error message and still on 3.5.3.
      Not sure if its related but if I type a simple gcode program for a motion test in Text Editor that file is not visible when attempting to "upload and start" in DWC. I've done this numerous times on a Windows PC/D2. I can copy the contents of the file and paste into command line in DWC and it will run.
      Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
        jay_s_uk @3DPMicro
        @3DPMicro try clearing the browser cache first. Then if that doesn't work, look at the settings page and post here the software versions it reports
        3DPMicroundefined 1 Reply Last reply Reply Quote 0
        • 3DPMicroundefined
          3DPMicro @jay_s_uk
          @jay_s_uk cleared browser cache and all caches on Pi. Same result
          Not sure what settings page you're referring to but this is the Pi-
          Static hostname: DuetPi5
          Icon name: computer
          Machine ID: 7e998385bd524f4785c399fb36e35c9d
          Boot ID: c362cc122f804b49ac09ddf9ad72788e
          Operating System: Debian GNU/Linux 12 (bookworm)
          Kernel: Linux 6.6.51+rpt-rpi-2712
          Architecture: arm64
            jay_s_uk @3DPMicro
            @3DPMicro the settings page in DWC
            • 3DPMicroundefined
              3DPMicro @jay_s_uk
              @jay_s_uk
              Duet 3 MB6HC MB6HC 3.5.3
              Duet Software Framework DSF 3.5.4
              Duet Web Control DWC 3.5.4
                droftarts administrators @3DPMicro
                @3DPMicro Send M997 on it's own to update the 6HC. M997 S2 updates DSF. DSF and DWC are up to date with the current latest release 3.5.4.
                • 3DPMicroundefined
                  3DPMicro @droftarts
                  @droftarts
                  @jay_s_uk
                  That did it. Thanks for the help gents. If I would have read the 6hc/sbc documentation carefully enough I should have picked that up.
                  Not a necessity but it would still be nice to know why a text file writen on the Pi isn't recognized by DWC upload and start.
                  3DPMicroundefined 1 Reply Last reply Reply Quote 1
                  • 3DPMicroundefined
                    3DPMicro @3DPMicro
                    To anyone in the future that is creating files, like hand typed gcode in "text editor" on their Pi and can not figure out why DWC "upload and start" won't recognize the file its because the file name needs to end with .txt (or .gcode, etc). The Pi text editor doesn't have a file extension by default. A bit of a doh moment for me when it slapped me in the face
                    • dc42undefined dc42 marked this topic as a question
