    Can not connect via WiFi after update to 1.21
    Firmware installation
    • appjawsundefined
      appjaws
      transferred from another thread, hoping for some help.
      I was running rc4 and have updated to 1.21. I expected this to just work.
      I uploaded the Duet2CombinedFirmware.bin, DuetWiFiServer.bin, iap4e.bin and DuetWebControl.zip files. When the duet rebooted it could not connect.
      The USB printer interface connected to the printer so I tried to run M997 S0 to install the firmware again but this did not work.
      I then erased and reset the board and used BOSSA 1.18 to install, so device manager shows Duet 2 WiFi or Duet 2 Ethernet 3D printer control electronics (COM5)
      Then reset the board and connected the USB again. The printer is online but when I send M997 S0 I get the error Can't read from printer (disconnected?).
      I have followed the Fallback procedure instruction on https://duet3d.dozuki.com/Wiki/Installi … g_Firmware
      I am now stumped How can I resolve this?
      This is the result of M122 after disabling M552 S1 in config .
      SENDING:M122
      Used output buffers: 1 of 32 (1 max)
      RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.0 or 1.01 + DueX5
      Board ID: 08DAM-999TL-NL5T8-6J1DL-3SJ6P-T65BJ
      Static ram used: 16152
      Dynamic ram used: 100440
      Recycled dynamic ram: 2192
      Stack ram used: 3576 current, 4456 maximum
      Never used ram: 7832
      Last reset 00:00:13 ago, cause: power up
      Last software reset at 2018-03-12 17:04, reason: User, spinning module GCodes, available RAM 7768 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      SD card 0 detected, interface speed: 12.0MBytes/sec
      MCU temperature: min 18.1, current 21.3, max 21.4
      Supply voltage: min 0.0, current 0.0, max 0.0, under voltage events: 0, over voltage events: 0
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Driver 5: ok, SG min/max not available
      Driver 6: ok, SG min/max not available
      Driver 7: ok, SG min/max not available
      Driver 8: ok, SG min/max not available
      Driver 9: ok, SG min/max not available
      Expansion motor(s) stall indication: yes
      Slowest main loop (seconds): 0.000242; fastest: 0.000047
      MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "M122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is disabled
        WiFi module is disabled
        Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
        === Expansion ===
        DueX I2C errors 0
      This is after re-enabling M552 S1 in config
      === Network ===
      • WiFi -
        Network state is starting
        === Expansion ===
        DueX I2C errors 0
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
        @appjaws:
        That's normal because the USB port has to be closed to do the firmware upgrade; although it should print a message first warning you about that.
        Your M122 output shows the wifi module is disabled. So send M552 S0 to enable it, give it a few seconds, then if you run M122 again it should show the wifi firmware version in the network section.
        • appjawsundefined
          appjaws
          Thank you DC, Tried that but it didn't work.
          resolved
          For some reason it appears that the WiFi server had not started.
          re-installed and now all OK.
          Simplify3D 5.1.2
