New firmware 2.0RC5 available
  • @wilriker said in New firmware 2.0RC5 available:
    @bmmal I can confirm this. I tried 100mm and 50mm extrusion and it did barely extrude less than 100mm altogether - that might also explain why my print today hat what I first thought was a layer shift. Now it rather makes sense that extrusion was so low that bed adhesion failed at one point, moved the print and gladly found hold again in a place where I did not have to toss the print away.
    I will also downgrade to RC4 and check again.
    EDIT: I retested and now can no longer reproduce the problem.
    @BMMal how fast did you extrude? When I tried with 5mm/s it would fail most often. I tried again with 1mm/s and it extruded exactly 100mm on RC5.
    I have to retest. I found a mechanical problem and suspect there may be another. Working on it.
  • @bmmal said in New firmware 2.0RC5 available:
    More or less the same here. Too fast extrusion speed plus a bad angle in my Reverse Bowden. Retested twice now and both times perfect 100mm extrusions.
    Something is not adding up for me. I have tried both RC3 and RC5 and I'm getting half of what I should with both of them. I don't recall changing anything with my steps/mm or microstepping...
  • @bmmal What speed are you testing with? For me 1mm/s works fine, 5mm/s did not reliably extrude the requested amount - at least not with the bad angle in my reverse bowden and a comparably weak ungeared extruder setup.
  • @wilriker
    1mm/s
    Usually 5 is just on the edge of too fast.
    Found that out as well. 😉
  • @wilriker So not really sure what it was, may have been a combination of the way I had my steps/mm for each extruder and microstepping explicitly defined ie Exx:xx:xx:xx rather than just Exx.
    At one point it looks like I had the arrays mismatched in size so default 16x were being loaded rather than the 8x
    Seems to be back to normal now...
    Happy to hear that. 🙂
  • These are the last two entries in "Network" (debugging console)
    penultimate
    Request URL: http://192.168.188.40/rr_status?type=1
    Referrer Policy: no-referrer-when-downgrade
    Provisional headers are shown
    Accept: application/json, text/javascript, */*; q=0.01
    Referer: http://192.168.188.40/
    User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/66.0.3359.181 Safari/537.36
    X-Requested-With: XMLHttpRequest
    type: 1
    Last entry
    Request Method: GET
    Status Code: 200 OK
    Remote Address: 192.168.188.40:80
    Connection: close
    Content-Length: 168262
    Content-Type: text/html
    Accept: */*
    Accept-Encoding: gzip, deflate
    Accept-Language: de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7
    Connection: keep-alive
    Host: 192.168.188.40
    @zerspaner_gerd said in New firmware 2.0RC5 available:
    Thanks, those all look OK. The 404 errors for those particular files are normal.
    One difference between 2.0 and earlier versions is that the total size of output buffers is reduced in 2.0. Because of the way that DWC fetches the file list, this means that the number of files that DWC will display in a single directory is about 1/3 lower than it was before. So if you have a lot of GCode files on the SD card and you do not organise them into directories, then you will not see new files that you upload into the /gcodes folder in DWC even though they are there. The workaround is to create subdirectories and move some of the files into them.
    What other problems are you having with 2.0RC5 and DWC 1.21.1 final?
    @denke said in New firmware 2.0RC5 available:
    gcode file delete problem threw dwc:1.21.1, fw:2.0-rc4:
    ->http://printer.loc/rr_delete?name=0%3A%2Fgcodes%2Fvase.gcode
    <-{"err":1}
    Message displayed: Error: Cannot delete file 0:/gcodes/vase.gcode because it is open
    There was no print or simmulation since cold bootup, just deleted a bunch of other gcode files.
    After "emergency stop" the file deleted successfully.
    It may be that at the time you tried to delete the file, DWC had it open because after the previous file deletions it rescanned the files for the GCode information. Did you try deleting it more than once before you did the emergency stop?
  • @dc42
    Yep, about 6-8 times across the duration of about 2 minutes. I opened the debugger on maybe the 4th time I tried it.
  • Also, another strange experience, Not all the gcode files were listed in dwc, and I could not fild any method to turn the page.
    -I selected the sorting method of mtime, newest first, but the most recent prints did not show up.
    -Then selected all entrys, right click, delete.
    -The selected entrys were deleted, and a new set of gcode files appeared containing those most recent I was looking for.
    As if not all the entries were in the list of gcode files, and the sort would only apply to those which were visible.
  • @dc42 said in New firmware 2.0RC5 available:
    Thanks,
    Another problem is the DWC with this error (rr_status? Type = 1 in red, see picture above) stops responding.
    Comes between 7 and a maximum of about 30sec.
    There is no message, I only see it in the debugging console.
    I could confirm if I choose a folder, the gcode file is displayed.
    But is that the reason for the DWC problem?
    Should I again downgrade to DWC and RRF 1.21, move gcode, and then try again on 1.21.1 und RC5.
    That sounds exactly like one of my problems!
    Did you try that:
    Wenn Sie also viele GCode-Dateien auf der SD-Karte haben und diese nicht in Verzeichnissen organisieren, werden Sie keine neuen Dateien sehen, die Sie in den DWC-Ordner / gcodes hochladen, obwohl sie vorhanden sind. Die Problemumgehung besteht darin, Unterverzeichnisse zu erstellen und einige der Dateien in sie zu verschieben.
  • Sitting on the 'G-code files' page, while aprint is in progress, I received this error message:
    G-Codes Directory
    Go Up
    Connect to your Duet to display G-Code files
    JavaScript Error
    A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
    Version: 1.21.1
    Message: uncaught exception: out of memory
    URL:
    Line: 0:0
    Error object: "out of memory"
    See my earlier response, https://forum.duet3d.com/topic/5394/new-firmware-2-0rc5-available/30. There has always been a limit to how many files DWC will display in a single folder, but it's a little lower in release 2.0.
    @dr_ju_ju said in New firmware 2.0RC5 available:
    G-Codes Directory
    Go Up
    JavaScript Error
    Version: 1.21.1
    URL:
    Line: 0:0
    That's one for chrishamm.
  • @dc42
    Thanks for the info!
    A behaviour suggestion if i may:
    -The sorting could be implemented in the duet fw, not dwc.
    -The board could send down the first ~25 entries initially (the first 25 of the sorted list), then send the follow-up entries threw page turning or infinite scrolling
    Or at least a warning that "there are too many files in this directory, not all files are shown".
    Thanks, I am already in discussions with chrishamm about how to resolve this.
  • Nice, thanks @dc42 !
Locked
