Oddblobbs :) Looking for some assist to settings
  • Hi all,
    I have been quite happy running my duet wifi on my homebuild kossel mini for a few months now (just casually running it during weekends here and there, so no pro by all means)
    I am perhaps running a few fw versions behind at:
    Firmware Name: RepRapFirmware for Duet WiFi
    Firmware Electronics: Duet WiFi 1.0
    Firmware Version: 1.20beta8+1 (2017-11-18)
    WiFi Server Version: 1.20b9
    Web Interface Version: 1.19.3
    Generally I am very happy with dimentional accuracy of my print for practical stuff, but I have been having start/end blob issues to my moves and I have started to experiment with pressure advance settings as I would like to print a few more aestetic figures and not just my current mounting brackets and hooks 🙂
    However, I am not having much luck with my current troubleshooting, so I thought I would post my settings here for you to critique if anyone have the time to look through.
    Some background, .. Firstly, my printer is a mini kossel with a capricorn bowden. I have a e3d v6 hotend and a duetwifi + smarteffector setup (calibrating to 0.007 which I am quite happy ). I am on 24V.
    From config (sorry about my obvious comments, but I am quite new to this..)
    M92 X100 Y100 Z100 E815 ; Set steps per mm (Extruder steps mm) 837 corrected from wiki > 815 (5.02.2018)
    ;For 256microstepp from 100 -> 1600
    M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
    M906 X1300 Y1300 Z1300 E900 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    G21 ; Work in millimetres
    I am uploading a couple of pictures for reference.
    The blobs come at both start and end of move. For the benchy they are at the same spots for the different settings I have tried for the pressure advance:
    M572 D0 S0.05 and up, but when I go over 0.2 my extruder seems to start grinding away at my filament. I did not try lower.
    I used S3D and have following settings:
    1_1528925829933_s3d2.JPG and
    Clearly the devil is in the relationship between my retraction, speed and jerk, however... after a good while of blind guessing and reading through posts, I am still not getting it right. Simply I am not "getting" it 😞
    I am sure some of you could instantly spot my err and I would be very grateful to any pointers to further try out.
    On a more positive sidenote:
    I had a small session about 3d printing and coding to 50 young boys in a school here in Dublin today. It is very cool to see them inspired by this technology and the kossel makes for a very interesting object to watch as it makes wonderful movements. Next month I will be showing the minikossel on a stand at Dublin Maker 2018, so if anyone is in town, do hook up for a light chat and a Guinness 🙂
    Here is a picture of it in action, but only showing without the kids 🙂 So much fun.
    Pps: New forum looks/works great!
    The blobs may just be due to insufficient retraction. How long is the Bowden tube on your Kossel? Do you have clips under the collets at the ends of the tube to lock them in place?
