Change V_Fan Select Header to 3 Way Plug
  • Hello, as the heading suggests can the 3 way pin header that is used to select V-IN or 5V for the fans be changed for a 3 way plug like the limits or stepper motor plugs? I remove the jumper and feed the central pin directly so that I can use a specific voltage (in my case 24VDC) but be able to isolate the supply to the steppers and heaters separately to the fans. The three way sockets don't engage positively with the header and is vulnerable to wriggling off!
    Edit; sorry this should have been in the hardware wishlist section.
  • Moderator
    I used a single DuPont connector and it seemed to wedge very tightly onto the pin.
