    Need help in setup a cartesian printer
    • sergiucip
      sergiucip last edited by
      I need help to understand where is the problem when i do atuocalibration or Mesh grid compensation, i believe th G30 command is the problem or i am not doing something right.
      Details:
      Home X working good
      Home Y working good
      Home Z working good
      When i try to do G30 command printer is behave like is out of limits. Move in X Axis is passing the endstop and the coordinate si set 0,0,0 but in a middle of the one axis, like the absolute coordinate is translated and is out of sync.
      my config g is:
      ; generated by RepRapFirmware Configuration Tool on Wed Aug 22 2018 13:56:44 GMT+0300 (Eastern European Summer Time)
      M550 PMICROBOT ; Set machine name
      M552 S1 ; Enable network
      M587 S"CRM_DEV" P"CRM_DEV" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S1 ; Enable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes backwards
      ; Microsrtepping
      M350 X64 Y64 Z32 E32 I0 ; Configure microstepping without interpolation
      M92 X320 Y320 Z1600 E420 ; Set steps per mm
      M566 X1200 Y1200 Z1000 E6000:6000 ; Set Jerk/maximum instantaneous speed changes (mm/min)
      M203 X20000 Y20000 Z600 E8000:8000 ; Set XYZ and E0:E1 maximum speeds (mm/min)
      M201 X600 Y600 Z150 E2000 ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1800 E1800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 I30 ; Set idle timeout and motor idle factor in per cent
      G21 ; Work in millimetres
      M208 X199 Y193 Z173 S0 ; Set axis maxima
      M574 X1 Y1 S0 ; Set active low endstops
      M574 Z2 S2 ; Set endstops controlled by probe
      M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M556 S0 X0 Y0 Z0 ; Set orthogonal axis compensation parameters
      M557 X0:160 Y0:180 S40 ; Define mesh grid
      M305 P0 X500 ; Configure thermocouple for heater 0
      M305 P1 X501 ; Configure thermocouple for heater 1
      M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H0 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H0 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      T0 ; Select first tool
      homeall.g is
      G91 ; relative mode
      G1 Z4 F200 S2 ; raise head 4mm
      G1 X-204 Y-198 F3000 S1 ; move up to 240mm in the -X and -Y directions until the homing switches are triggered
      G1 X4 Y4 F600 S2; move slowly 6mm in +X and +Y directions
      G1 X-10 Y-10 S1 ; move up to 10mm in the -X and -Y directions until the homing switches are triggered
      G90 ; back to absolute mode
      G1 X100 Y100 F2000 S2; put head over the centre of the bed, or wherever you want to probe
      G30 ; lower head, stop when probe triggered and set Z to trigger height
      bed.g is
      M561 ; clear any existing bed transform
      ;M401 ; deploy Z probe if necessary
      G30 P0 X0 Y0 Z-99999 ; define 4 points in a clockwise direction around the bed, starting near (0,0)
      G30 P1 X160 Y0 Z-99999
      G30 P2 X160 Y180 Z-99999
      G30 P3 X10 Y180 Z-99999
      G30 P4 X100 Y100 Z-99999 S0 ; finally probe bed centre, and calculate compensation
      ;M402 ; retract the Z probe
      G1 X0 Y0 F5000 ; move the head to the corner (optional)
      Can somebody help me to understand what is wrong in my setup
      adavidm 1 Reply Last reply Reply Quote 0
      • adavidm
        adavidm @sergiucip last edited by
        @sergiucip said in Need help in setup a cartesian printer:
        This might not be your problem, but that looks like an anticlockwise pattern, rather than clockwise as required. By convention, (0,0) is the bottom-left hand corner of the bed, and (xMax, yMax) is the top-right corner.
        Note that the motion of the nozzle, relative to the bed, is what's needed here. With moving-Y printers, this can be counter-intuitive.
        adavidm
        • sergiucip
          I have a correct bed.g now, behaviore is the same, when i do G29 actually it will go correct until the end,but in the final sequence after the last point is scanned the Y axis pass the end stop parc the head in the middle of X axis and set the coordinate X=0,Y=0 but is not in the origin point (X=0,Y=0)
          • sergiucip
            Few...i find what is wrong...for anybody with this issue you need to delete deployprobe and retract probe.g from sys
            Thank for the help
              Sounds like somehow you ended up with recent firmware but an old SD card image. In which case, your resume.g file may need to be updated.
