Question about M666
  • Hi,
    I was reading an article on delta printers that was trying to explain what M666 does.
    For what follows assume a delta printer where the Z endstop is spot on, the X endstop is 1mm higher and the Y endstop is 2mm higher.
    The article said that for those conditions the correct command was M666 X-1 Y-2 Z0
    It also seemed to be saying that during homing, after triggering the endstops, the X carriage would be moved down by -1 and the Y carriage by -2.
    Is that correct?
    If not what exactly does M666 do?
    Thanks very much.
    I think that description is correct for Marlin firmware, which requires all M666 corrections to be negative. RepRapFirmware behaves differently and does not have that restriction.
  • @dc42 said in Question about M666:
    Hmm... That may well be the case. It was an older article.
    The current M666 documentation is somewhat vague as to how it works
    Based on some further research and experiments I think I understand what M666 is doing.
    Thank you.
