    Check Bed compensation...
    • peirof
      peirof last edited by
      i d'like check if Heighmap in bedcompensation its ok...
      What will be the procedure for check Heightmap??
      Thanks
        I usually move the nozzle tip close to the bed say 0.5mm above the bed and then move the nozzle around slowly and see if the height of the nozzle stays consistent.
        fcwilt 1 Reply Last reply Reply Quote 0
        • fcwilt
          fcwilt @Phaedrux last edited by
          @phaedrux said in Check Bed compensation...:
          I don't suppose there is any kind of utility that can generate a gcode file for doing this - one with just the XY movements.
          I know I could create one "by hand" but it would be nice if there was a utility I could use.
          Thanks.
            Phaedrux Moderator @fcwilt last edited by
            @fcwilt If you wanted to verify by printing I use this STL. Just scale it to your bed size
            0_1536254494238_bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
            fcwilt peirof 2 Replies Last reply Reply Quote 0
            • fcwilt
              Thanks.
              I will give it a try.
              • peirof
                peirof @Phaedrux last edited by
                @phaedrux thanks
